I was using my L4400 today to move some dirt to enlarge a small pond. I also had a box blade on the 3 point hitch. After an hour or so, the front end started not responding correctly to the valve. The curl and dump directions were working correctly , but the boom up and down was not working right. It would go up if I combined the curl AND up, meaning if I moved the lever in a 45 degree angle upward. Same thing to lower the boom. I had to move the handle in a 45 degree angle downward. All of this didn’t start until I had been on the tractor for a while. I used the box blade to drag up and down the driveway for at least an hour or so.
I checked the hydro fluid level and it was ok. Does it sound like there is trash getting into the valve somehow. Any ideas?
