Favorite Chemicals for Coolant Flush
Zatzke
L305DT
Jul 11, 2014
22
Otsego, MI
I've done plenty of coolant flushes in mostly the automotive and powersports world, but usually I do it is as PM instead of a response to a problem.
My Kubota L305DT is getting warm when at PTO Operating speed and tends to stay up there until I throttle back and reduce the load. I've had a slight amount of coolant boil over and after inspecting the radiator, the cores look to be a bit scaled up and in need of a good cleaning. So my question is - who has used what and what do people recommended? I'm looking for a chemical additive (or different process than garden hose flush) to aid in getting the cooling system clean and operating efficiently again.
There's a bunch of different home remedies and off the shelf "mechanic in a bottle" solutions :rolleyes: so lets here some opinions!
To cover the bases about the overheating, here's what I know about the situation:
-Screen and fins are clear
-Haven't pulled the thermostat, but this isn't suspect because the temps regulate back to normal and stay there. I can also sustain the "high temp" where it is at based on load and always bring it back down by unloading the tractor. I could always pull it and check it on the stove, but I need to clean the system regardless
-Water pump appears to be circulating coolant through the radiator properly, whether it's "up to spec" or not, I can't verify. I am doubtful this is the problem.
-Head gasket isn't in the mix as I'm not getting coolant in the oil/white smoke out the exhaust/black floaties in the coolant/or over-pressurization of the coolant from combustion gases
-Have checked temps with a different gauge and am getting up to about ~220F before I start lowering the load. It probably could go higher, but i don't push it at that point
-Oil has been changed recently and is still clean (not overheating from the engine oil)
ipz2222
L235, bx2670
May 30, 2009
1,927
34
38
chickamauga ga usa
I was in the same boat with a neglected bx2230. Out of several suggestions, I chose Arm and Hammer washing powder. Drained the radiator, mixed 1 full cup of powder with 1/2 gallon of HOT water. Poured the hot mixture and toped it off with water. Run the eng for at least 1/2 hour. Drain it out, run again, drain, fill, run... 4 to 5 times, gets all the soap out. It was amazeing how clean the radiator was when I finished. Fill with Fleetcharge antifreeze from TSC.
Tooljunkie
May 13, 2014
4,150
35
Radiator specialties rad flush. Heavy duty type.
Pull thermostat and flush it repeatedly til clear.
I have used simple green to degrease or remove oily residue. Its awesome .put in a cooling system after a trans cooler failure. Made it spotless.
Might have to try arm and hammer.
Zatzke
L305DT
Jul 11, 2014
22
Otsego, MI
I've heard about the Arm & Hammer solution - I may have to give that a whirl just from a simplicity and low cost aspect! If it doesn't work - hey I'm not out a whole lot! :D
Hopefully, you have checked and cleaned the radiator screen and cleaned the exterior of the radiator as well. (You mentioned that this was done.)
But to your question, I use Tri-sodium phosphate (TSP). It doesn't foam and does a great job of cleaning. It doesn't foam either.
http://www.homedepot.com/p/SAVOGRAN-1-lb-Box-TSP-Heavy-Duty-Cleaner-10621/202935861
Radiator screen is clean
I've used TSP for other projects, but can't say I've ever thought to use it in a cooling system... I know it works well on grease and the likes, but does it work well on scale buildup? I suppose it wouldwork very similarly to the Arm and Hammer as they both have a pH relatively close to each other... Sodium Bicarbonate (aka Arm & Hammer Washing Soda) has a pH of 11.6 where as the TSP has a pH of 12.0. So in theory (all other chemical reactions ignored - I'm not a chemist :eek:), the TSP should work better right?
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Just a simple bottle of white vinegar and distilled water will gently remove any scale deposits, but it needs to sit for a while. If you have other issues like grease or additive contaminants then I don't know if the vinegar can deal with that.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
19
Northern California
The TSP will take care of most of the cleaning aspects. But for calcium scale, which is also high in Ph, an acid is needed. Vinegar has already been mentioned, but CLR brand (Calcium, Lime, Rust) would work even better.
CLR does have to sit for a while, like vinegar, and is far more expensive. If I was doing the job, Costco or Sam's Club sells large bottles of vinegar for cheap. Fill the system with straight vinegar and run it a while since heat speeds chemical reactions. Leave the tractor overnight, drain, refill with vinegar, do it again. Then flush and fill with 50-50% anti-freeze and water.
That is about all you can do at home. The next step is a radiator shop if all else fails.
Hopefully, your diagnosis of the overheating problem is correct. You seem to have an excellent grasp on the issues that cause overheating so just revisit them one by one if the radiator cleaning does not produce the desired results.
Tooljunkie
May 13, 2014
4,150
35
Have read of someone using draino, but i like my tractor too much. Too nervous to try it. Less harsh chemicals over longer time is more my preference
OldeEnglish
Jul 13, 2014
766
Western, MA
I've dealt with the same problem within copper piping systems and also ice making machines. I've looked into using CLR but if you read their instructions they mention not to use it on copper. You guys may want to look into a ice machine cleaning solution. You have to cut it with water properly, but it destroys calcium deposits and is safe for copper when cut properly. Just make sure to flush it cleanly out of the system so it doesn't change the PH of your antifreeze. You can pick it up at any plumbing/HVAC supply store. Vinegar works great too. I use it full strength to flush tankless water heaters when calcium builds up within the heat exchanger. I fill a 5 gal bucket with vinegar and circulate it through the heater with a transfer pump. I let it go for a few hours and it turns the vinegar dark green. Works like a charm and restores the proper heat exchange, but the exchangers and piping within the heater are typically stainless steel. For cleaning coils or a core, heavy duty HVAC coil cleaner works great. I haven't used it on a radiator yet, but used it many times cleaning large HVAC air handler coils. Same thing only different. I spray it on full strength, let it sit for a long time, spray again, and wash it off with a hand pump sprayer (strong enough to wash dirt and grime off but gentile enough not to damage the fins). They make both a liquid and a extra heavy duty foaming spray, also available at any HVAC supply store. Just be carful with anything highly acidic because it can destroy copper, and may create a new rust problem within the motor. Your own urine is acidic enough to turn copper into dust over time. Brass can hold up to acid without a problem, but many rubbers and plastics do not. Lime scale is a bastard to anything that flows water, Good luck!
OldeEnglish
Jul 13, 2014
766
Western, MA
Yeah I would never do that. I wouldn't even put in in my sewer drains let alone my tractor. :eek: Draino is an extremely strong base that will turn cast iron into dust, so I could only imagine what it would do to an engine block. Very bad stuff and trust me it doesn't work, only creates larger problems.
Zatzke
L305DT
Jul 11, 2014
22
Otsego, MI
I agree on not using Draino - too harsh for my liking... has anyone ever tried using one of the many citric acid cleaners? I know is a relativity gentle acid - I use it for cleaning brass for reloading ammo, but not sure if it would be strong enough for scale in a cooling system.
Just thinking out loud at this point...
I'll probably try TSP followed by vinegar if needed. Any idea if I should run the tractor with either of these cleaners in it to get some heat and pressurized circulation into the system or is better just to let it sit?
Heck - maybe I'll just fill the thing with Coca-Cola!!!! :eek: :eek: :eek:
Stubbyie
879
10
Midcontinent
There's more going on in the chemical reactions involved in radiator crud cleaning than can be judged by simply increasing the pH of the cleaning material.
And to further comment on the temperture increase, a rule of thumb (worth what most such rules are) is that a temperature increase of 10-degrees Celsius (approximately 18-degress F) doubles the rate of chemical reaction.
So if you bring your engine up to 170-deg F on the gauge from a cold start of 70-deg F then you have increased the temp 100-deg F so you could expect the cleaning reaction to proceed at approximately 5 times faster in the hot engine than the cold. For our purposes close enough.
So whatever cleaning reaction is going on is happening much faster than you thought and may for that reason be much more aggressive.
As for powdered products, dissolved in water, then used in the cooling system? I think this is a prescription for problems. Temperature and pressure changes inside the engine (pressure drop through the thermostat or through an interior cooling channel) or radiator could conceivably result in that powder dropping out of solution. And which due to chemical and structural changes, the powder once back in solid form may not want to be dissolved back into water. Now a real problem may exist that didn't previously.
Personally, I wouldn't introduce anything into a radiator I cared about other than distilled water or glycol.
I think if an owner really truly thinks the cooling system needs cleaning to that extent their first move should be removing the radiator, having it professionally disassembled and rodded and vatted and cleaned, reinstalling it with pure water and glycol, and then seeing if there is still a problem that the engine itself needs attention.
Offered for continued comment by this knowledgeable community of users.
Please post back your experiences so we may all learn.
Zatzke
L305DT
Jul 11, 2014
22
Otsego, MI
Stubbyie
I agree that none of these methods will yield a radiator as clean as bringing it to a professional to be worked over. I also agree that a new radiator would be an acceptable fix, although a bit more expensive. However, these methods will only clean the radiator and not address the rest of the cooling system. One could go another step and pull the motor, have it hot tanked/magnafluxed and the like to make sure the rest of the cooling system is cleaned, but then costs start getting quite high. There may be other ways that professionals can clean the entire cooling system that I am not aware of (controlled circulation of certain chemicals in a controlled environment could be one :confused:)
The purpose of starting this thread was merely to discuss cost saving alternatives to these methods stated above. Something that can help the regular Joe do some wrenching on his tractor at home to help improve his cooling systems efficiency. I understand why you may not want to jeopardize the integrity of your system with the home remedies as discussed so far, but my thoughts are that if I am going to have to pay someone to clean my radiator (or replace it), I might as well give it a low cost whirl at home first! Let's just hope that the gaskets hold up to the chemicals :eek:. I just don't want to get too far away from the main topic.
Ok - got sidetracked there... my bad :eek: Now on to the theory.
From past chemistry classes, I understand the heat acts as a catalyst to speed up the reaction but didn't know how much - thanks for those rough figures! I didn't know off the top of my head that the speed approximately doubles for every 18F. However, if we are talking mixtures and solutions, wouldn't a powdered cleaner dissolved in water technically be a solution? unless too much powdered cleaner was mixed in and it became more of a mixture... I know it is much more difficult to separate out a solution than a mixture. Essentially the solution would have to undergo a phase change or chemical change that precipitates out the cleaner. This would be a clear example where more cleaner would not work better than the proper amount of cleaner.
I am not sure here, but I wouldn't think the pressure or temperature differentials observed in a cooling system would be great enough to pull the cleaner out of solution. Since the cooling system only gets charged to less than 20 psi, I don't think the pressure differential would be greater than 20 psi would it?
I could see where something would happen if cavitation is a factor, but I wouldn't think that the cleaner would be subject to prolonged exposure to the extreme conditions of cavitation - therefore making this almost negligible.
I wouldn't want to truly "Operate" and "Work" the tractor going through this cleaning process, but merely have it running to get ambient heat into the cooling system to speed up the cleaning process. This would keep some of the more extreme operating conditions out of the picture.
None of this is meant to be contradictory or argumentative to what you have said - merely just thinking out loud and having a discussion.
Either way, I will be trying one or more of the methods previously discussed and will report back what I find! Hopefully I'll be able to get some bore scope images of before and after treatment. It might just be a little while before I get to it because i'm not sure what the meaning of "free time" is these days :(
OldeEnglish
Jul 13, 2014
766
Western, MA
I agree with the posts above of not running any cleaning chemicals through your system at any warm temperature, I never have, and should have been more in depth with my cleaning experiences.
If it was me, and my radiator had a scale build up inside the radiator, I would remove and flush it separately with a proper cleaning solution. Fill a five gal pail with the cleaning solution, submerge a pump in the pail, pump solution into one end of the radiator, and cycle the other end back into the pail. With radiator removed, I would attach a garden hose to one end of the engine and flush water through it until the water is clear. Take a sample of the exiting water in a small glass and inspect for any sediment. When clear, use a shop vac on one end of the engine, leave the other end wide open, and suck any residual water out of the engine so it does not dilute your new coolant mixture. ALWAYS LEAVE THE OPPOSITE END OPEN so you do not build a vacuum pressure and damage any seals. For the radiator, finish by flushing any residual cleaning solution out with clean water, and shop vac any remaining water out. That is very important in freezing weather, I've seen millions of dollars in damage resulting from residual water changing an antifreeze ratio. Easy way to double check is with some antifreeze test strips available at any car parts store.
My theory of why the gentleman is getting a scale build-up is because of electrolysis. The coolant was probably getting old, it contains rust sediment from the block, therefore the rust sediment is reacting with the copper core of the radiator creating scale. If the tractor had an aluminum block and didn't have any ferris metals within the system, you wouldn't get any electrolysis. This happens within heating/chilled water systems all the time, especially if the copper piping is not separated from the steel piping by a dialetric fitting. Those are either a nipple or a union that contains a Teflon sleeve. Just keep in mind that any type of system that flows liquid needs a periodic flushing. A radiator shop is not going to do anything more than I stated above, they may say they use special cleaners, but it's most likely vinegar because it works great. To be safe, a 50/50 mixture of vinegar and water will clean that radiator right up, it just may take a good 4 hours of circulating.
Definitely separate the two. I would say if you put a cleaning agent in your tractor like you stated above it will do what it is supposed to and break up any sediment. The problem is, the sediment will settle to the lowest point of the system, so therefore it needs to be flushed out. I wouldn't worry about using anything more than water in the block for cleaning because it will always rust over time even with antifreeze in it. If you flush the block and still visibly see some sort of scale or rust build up, try the same mixture of vinegar to break it up. Any fast acting chemical is going to be strong, some things prefer a mild agent over a long period of time to safely get the job done.
I hope this will be of any help!
Zatzke
L305DT
Jul 11, 2014
22
Otsego, MI
Very well put OldeEnglish. Although more work in the long run, I think that is a superior approach to doing everything in one shot.
I guess my thought with running the cleaner through the block was that if I can get most of the scale into suspension it would make it easier to flush out. I am not worried about surface rust building in the cooling passages as it should be somewhat minimal and a thin coating. I am more worried about any kind of lime/calcium deposits or other mineral deposits from a past owner not using distilled water.
My initial thoughts were to run a solution of TSP through the engine using a 5 gallon bucket and a pump as a circulation method. Simply pull the thermostat, drain the cooling system, refill with TSP solution, fill 5 gallon bucket with TSP solution, use pump to introduce solution to the cooling system and have a drain line back to the 5 gallon bucket. I may actually use a couple 5 gallon buckets set up in a weir configuration with a simple improvised filter or two to help solids drop out before being introduced back into the cooling system. When effluent looks clean, drain system and flush with hose.
I do like the idea of pulling the radiator and treating them as two separate systems though. I haven't looked at the cooling passages through the block yet, but I do expect that I will need to introduce some sort of cleaner to the block passages.
Tooljunkie
May 13, 2014
4,150
35
As zatske mentioned, i have used hot water and a commercial rad flush to do cooling systems in cars,its amazing what ends up in pail after a few minutes of circulating.
OldeEnglish
Jul 13, 2014
766
Western, MA
Zatcke - that sounds like a good plan of attack to me and I like your idea of the 2 pail configuration to help separate the sediment. It's good to know that an increased temperature helps the cleaning process. I've never tried it because basically I'm usually working on a very large scale unlike a small scale of a tractor or car. I'm curious if anyone that does this on the regular uses some sort of flush cart? I've used a large style flush cart on geothermal systems and a few heating systems. It's basically (in my case) a large pump, in line filter, and a vertical standing large pipe with one open end. You hook it up as a loop, the pump circulates through the system, through a filter, dumps into the standing pipe, and draws off the bottom of the pipe back into the system. For my uses it basically purges the air from the system but also filters the water. They typically have a powerful pump to be able to move water through a very deep geo well or a large piping system. In our uses here you could just Build a small scale one to mainly filter the cleaning solution with a small transfer pump, a pail, and a small inline filter. I think that would take care of the sediment problem, but maybe I'm getting a little to crazy :eek:. Here is a picture of the one I've used to give everyone a visual idea.
Tooljunkie
May 13, 2014
4,150
35
In one dealership i worked in had a similar machine, pulled upper rad hose, coupled in apparatus and it would pulse fresh coolant into rad, every pulse would force thermostat to open and coolant would pass out thermostat housing. I didnt care for it, preferred to drain and flush. Would work well on an open system though.
OldeEnglish
Jul 13, 2014
766
Western, MA
Tooljunkie that's interesting, I figured if someone was to do that on the regular they would have some sort system to help get the job done quickly.
