f2260 with locked up front wheel
RTHawes
f2260
Jan 29, 2014
Battle Creek, Michigan,
my 2002 f2260 was running great and blowing snow when we stopped for a few minutes and then when I tried to get going again the right front wheel was locked. All 3 other wheels drive are working and will spin forward and in reverse. I looked around for a locked up leaver or spring, or snow packed someplace but there isnt anything that looks broken or packed up.
Any ideas what would cause this?
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
Am not familiar with f2260. Is the base unit a commercial mower? Is it hydrostatic, 4wd, etc.
Possibilities: frozen, seized bearing/bushing, blown spindle, (does it have cv joint?)
10,259
Try engaging the differential lock and see if it will move, if it does but with that wheel still not tuning then it has a broken final drive gear and or seized bearing.
If it does not move at all it could be the same problem or a problem with the differential gears.
If by the odd chance it does start to move with the differntail lock engaged it's still possible that it has a sized bearing and your just providing enough power to make it turn, DONT run it like that it will do more damage and will just cost you more to get it fixed!
In any case, it's sounding like it's going to need to be torn down and repaired.
Fallon
L3200
Sep 10, 2013
19
Parker, CO
Diff lock only affects the rear diff, not the front. If the front left turns, power is getting to the front diff. My guess is a bearing or something else in the axle or final drive is toast. Trying to move it without resolving the issue may cause other issues.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
10,259
Go look at the tractor/mower it's setup backwards, the front is the rearend!;)
Here is one for you to see.
