F-2400 HOW TO CHANGE BLADES & INNER GAUGE WHEELS?
Laddie2
F-2400
Jun 20, 2021
30
I just got an F-2400 4wd mower.
Inner gauge wheels missing & blades have seen better days.
Is there a way to swing the deck vertical or do I have to remove the deck?
Thanks for any help, Laddie
2,170
I would think you could ride over a "hillside" and allow the deck to over hang where the land goes down.
Parking brake on and it will allow you to climb under - I would get or borrow an impact to remove the nuts/bolts.
I had an old bushhog - it whipped my ass trying to remove the nuts that held the blades on .......
finally drove it over a small hillside and got under with a grinder;) .......
then again it may just be easier to remove and flip the deck! :)
MDCobraMan
Kubota L3430 Grand Open ROPS, L3430 Grand Cab, F2400
Jun 8, 2021
27
I have a F2400 too and use a slight hill to park on then lift the deck. Make sure you put a jack stand or something suitable to assure the deck doesn't come down on you.
arto98607
Kubota F3060, Grasshopper 721D, Ford 1310, JD 440 ICD, JD 300
Aug 24, 2014
64
Southwest WA State
I am not familiar with F2400 and am not sure if your deck has that feature but owner's manual for your mower deck would cover it.
My F3060 came with RC72R-F30 Rear Discharge Deck and has it's own manual which covers how to put it in "Safe Position"
I just replaced the blades yesterday and flipped the deck as shown, but instead of 2x8 boards, I just drove it onto car service ramps.
Swinging the deck like this takes a little bit of muscle but is perfectly doable by one average size guy.
Helper would be handy.
Laddie2
F-2400
Jun 20, 2021
30
I do not have an owners manual.
Laddie2
F-2400
Jun 20, 2021
30
I jacked the front end about 8" put wood under tires, put 2x4 under deck.
I made 3 - 7/8" ID x 1 1/8" OD bushings/sleeves on my Reed Prentice lathe.
24 1/2" blades were hitting the deck.
So I trimmed 1/4" off the diameter on my Bridgeport milling machine.
Now it works like a charm.
arto98607
Aug 24, 2014
64
Southwest WA State
Sounds very good glad it worked out!
Is it possible to swing your mower deck to a vertical "service" position like shown in post #4 above?
Could you post a photo from above to give us some idea of what the deck looks like?
