Exhaust Pipe
Workerbee
Zd21
Mar 1, 2020
330
194
MN
Where would you source some bent exhaust pipe?
I wanted to redirect the exhaust on a repower. Its small like about 1-1/4” or so. I asked at a shop that does automotive systems and they told me they dont have the pipe or dies to go that small.
I was hoping to find elbows and straight and just weld them on but cant seem to find much.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
Depending on the specific size it may be about the same as EMT electrical conduit. Many electric shops have hydraulic conduit benders. If you can tell them how many degrees to bend it you may get what you want.
Workerbee
Zd21
Mar 1, 2020
330
194
MN
Thanks for the lead DirtyDog. I’ll check that out.
And Roadworthy, yes I did think of that as emt is tubing same as exhaust pipe is, but I would rather get an elbow with a formed bell to go over this muffler pipe. I think itd make a stronger weld that way than butting them up and welding. But yes its an option. Thank you!
BigG
Sep 14, 2018
1,953
774
West Central,FL
Looking at Dirtydeed's (the Amazon page)answer made me think about all the generators on the RVs. Maybe the Rv dealers have or make what you need because I am sure that the exhaust on the generators are not off the shelf items.
BobbyK
1995 B2400
May 20, 2018
102
44
Petrolia, Ontario
Electrical conduit is a good idea.
Just checked Lowes site and they have 1"1/4" + 1'1/2" conduit for $17.00-$20.00 for 10 feet.
BigG
Sep 14, 2018
1,953
774
West Central,FL
Different things such as pipe, PVC, are measured differently. Make sure that the 1 1/4 " are measuring the same either the inside or the out side diameter.
SidecarFlip
Banned
562
JC Whitney sells mandrel bent pipe in many different shapes and sizes.
motionclone
May 4, 2018
1,399
996
Maine
If you end up using electrical conduit its probably galvanized so be careful when welding that, fumes not good
Glassman13
51
10
Amherst Ohio
On my 2301 I used EMT 1 1/4 in. 90 degree and cut off what was'nt needed to get the angle I wanted. It slipped right on and the bends in both pieces made it wedge on, banged it with a rubber hammer and has'nt budged since. No clamp needed!
Workerbee
Zd21
Mar 1, 2020
330
194
MN
Lots of excellent suggestions. Much appreciated!
200mph that site you linked sure has some nice looking pipe and the prices seem ok too. I was going to stop by the elec shop I get supplies from and measure some EMT before ordering anything though. Hopefully that works out fine as itd be easiest all around.
200mph
Mar 3, 2017
1,228
65
PA
Please post back your solution and pictures if you can.
Good luck.
3,716
ONE exhaust “shop” is not the all-answer-to-all. Find another shop.
I live waay out (been practicing social-distancing for years.... I live in the country!)... Anyway, I wanted to extend the length of a contractor-rack on my pickup and went to an exhaust shop out in the county. He told me it’s an unusual size for exhaust systems, likely metric, but he put a caliper on it, and ordered tubing. Three days later it was cut, jigged, and welded onto my rack. He used 3-feet of the 20’ tube he had to buy as a minimum and have shipped-in... Cut two 1-1/2’ sections, cut my rack to separate it and spliced the two sections into it. He spent an hour just making a jig to assure alignment. The result looks original. Charged a total of $100. :p
Find another shop. Maybe one that’s hungrier.
