My Kubota L2550 has 180 degrees of steering wheel play when the tractor is off. I recently replaced the Power Steering pump, 31391-76103. Everything seems to work fine, no play when the tractor is running and the power steering is pressured up, but 180 degrees of steering wheel play when the tractor is off.
Any ideas on what is causing this? If was a worn bushing or something similar, I would think the play would exist whether the tractor was running or not. The Kubota dealer wants big bucks to trouble shoot the problem in my 40 year old tractor, and if I don't have to spend the money, I would rather not.
Possibly what ever the problem is will eventually fail and I will have to have it fixed. The question is, if I cannot fine and fix the problem now, will continuing to use it as is cause a much more serious, costly fix later.
Thoughts, comments???
