I have a good Kubota three cylinder engine. It is a model 1403. I want to put it in a Kubota L245DT tractor. I see the front differential bolts directly to the engine block unlike the tractor I have it in now, which uses some metal plates along the side of the engine block to mount the front differential. Does anyone here know if the engine will bolt up to the L245DT front differential?
