Electrical Issue with BX2230D
JSB
BX2230 w/ frontend loader, mower deck, and box blade
Dec 2, 2014
9
La Grange, TX, USA
I have a 1989 BX2230D that has been a very reliable machine. I have done a good deal of maintenance on it and still ran strong until day before yesterday. The wife was operating it, shut it off to talk to me about the fencing we were working on and when she tried to start it the starter turned over just fine but would not fire. Carried it to the shop and checked the fuel filter, even replaced them. Checked the fuel pump and is not getting voltage to the pump. When the key is turned on it does not energize the hour meter or anything else on the dash. It does engage the solenoid for the kill switch, but that is it. When you turn the switch to start it engages the starter, but there is no fuel to the injector pump, thus it does not start. I have checked the fuses. There was one 15amp fuse that was burnt pretty badly as well as the fuse holder, but there is no voltage to that fuse holder or any of the fuses.
I suspect a short, a disconnect, or possibly a fusible link. It is strange that it was running fine then all of a sudden quite.
Any suggestions are appreciated.
8,764
Check for a fusible link or master fuse down by the starter.
Other than that it sounds like you have a major short somewhere in the wiring.
6,634
JSB, sounds like you've checked the start problem pretty well. Like North Idaho Wolfman said, something in the electrical system not making contact.
Isn't it an every day thing when you're working on a specific project, wife comes by with a question or two, or maybe just lunch....and then she can't get back to what she was doing and it requires you to quit your job! Murphy hides everywhere!!
