Electric wood splitters
David Page
Jun 25, 2013
381
66
Dexter, ME
I searched but didn't see anything on it. Most seem to be 5 ton. Has anyone had experience with them and if so do they split much ? Thanks
lynnmor
B2601-1
May 3, 2021
1,320
1,036
Red Lion
I've split a lot of wood over the years, a 22 ton was the smallest and there were times that it just wouldn't do the job. My thought is that the 5 ton might be handy to do splitting indoors where a gas engine can't be used.
hodge
Nov 19, 2010
2,854
367
Love, VA
I've never used a 5 ton/electric one, but like lynnmor, I've split a lot of wood (primary heat for 3 households). I have a 32 ton, my dad has a 30 ton, and we sometimes hit wood that will task them. I can't imagine a 5 ton being sufficient other than for the lightest needs.
2,822
Seems in Europe thy use a lot of lectric splitters, some are just motors hooked to a big gear box others are hydro over lectric with box wedges,, I have even seen some firewood processors that were I have to assume 480 3phase. Though I dont think there are any American or Canadian companies that make big ones
blperk
B3200, FEL, Betstco 63" flail mower, B2782b front snowblower
Dec 25, 2018
21
Canandaigua, NY
I have used a 5 ton electric splitter for years on white and red oak up to 16" in diameter. It takes WAY longer than with a real splitter, because you can't just throw it in and split through the middle. You have to attack the chunks like you're doing it with a maul by splitting off slabs around the outside and eventually splitting it through the middle. If you have the time, it's a great alternative to an expensive splitter.
JWool
B2650HSDC FEL & Front Snow Blower, ZT-Z421, GL11000 Generator
Dec 29, 2013
97
17
Northern MI
I picked up a Swisher 22 ton, that seems to work great, cant say I have used it allot.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
730
522
canada
I have a 5 ton for indoor use, to resplit wood for when I want some small pieces. 5 ton is JUST enough, a 10 ton would be my choice. The 5 ton is good for a 4 inch maple piece, but not much more.
4,062
I've used an electric for almost 10 years. It's CLEAN and QUIET ! Yes, slow compared to a gas powered beast but at 69 , I'm in no hurry. The 'trick' was to cut logs to 'stove' cord size (12") instead of 'firewood' (16")/ Sure It won't handle 'big ugly' logs but it wasn't MADE for them. All scrap 2by4, get cut into footlongs, then become kindling. The last 'real'(gas) splitter I used had an 6" cylinder and 4 way wedge. It never,ever complained.
The Evil Twin
L2501, LA526,
Jul 19, 2022
2,391
2,302
A 5 or 7 ton is good for making fire pit wood. I've used a Hazard Freight one on Oak up to 10". It's not a fast process. So of you have trees to get rid of its not the right tool. If you want to make some firewood it could work.
jabloomf1230
B 3200
Sep 28, 2014
125
34
Voorheesville, NY
I have a Boss 7 ton. It very good for firewood length logs < 1 ft in diameter. It'll do bigger stuff if you're careful. It's quiet and easily moved around. It works with my EGO power station or an outlet.
trueg50
60
77
Vermont
Supersplits pair well with electric motors since it relies on kinetics and not so much the motor to split. I have the 5.5 horse gas and its an amazing splitter.
fruitcakesa
M 6040
Oct 26, 2010
852
265
Cavendish Vermont
I have had an electric Ramsplitter for about 8 years.220 volt 20 ton. Weld quality left something to be desired and I have rebuilt most of the metal parts over the years. But it has split a 6 cords a year for us with no fumes or loud noise.
