electric auxiliary connection
grsabourin
67
Quebec city
Hi
I would like to know a what is the best place to get electrical power to plug auxiliary instruments like lamps and electric clutch on a b7100
Thank you
2,170
Hi
Thank you
On that tractor aint no real good place - get you are relay via a fuse and go from there. Even on new tractors, users are taking a large diameter wire and running to a "new" fuse block - then running relays from there to lights and what not, thus the switch is not caring the amp load
Tooljunkie
May 13, 2014
4,150
27
Yup, generic fuse panel, with a generic relay. Main fuse directly from battery. Match main fuse to the load you will be applying, too large and its not protecting anything.
2,826
Soooo your sayin that rolled up gum wrapper is not a good thing huh,,,lol
Tooljunkie
May 13, 2014
4,150
27
I'd take a gum wrapper over a 22 caliber round any day.
Seen some pretty bad harness meltdowns in my days.
Worst one was a kenworth- 48 wires. Burned from fuse panel on passenger side to instrument cluster.
Cant protect wiring enough. Was a dash screw that worked its way into wiring.
