drive shaft b2650
danmorea
kubota b7100 loader/backhoe Kubota B2650 loader John Deere x540
Oct 25, 2013
95
15
narrowsburg ny
did not find any info
on my deere has grease points and if not greased could cost 2-3000 to fix
aaluck
Oct 9, 2019
928
746
Snowdoun, AL
If your talking about the 4WD the front axle has gear oil in there.
NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
Nov 28, 2015
424
Pennsyltucky
If the shaft is removable, it has grease points. One on either end. If its the "spline" you're referring to, then no, it sits in hydro fluid.
SidecarFlip
Banned
548
Not really. Just the ends. The intermediate shaft is enclosed (on my units it is) and there is a coupling on it (again my units) that can be replaced but it needs no lubrication except an initial greasing (in the coupling). It's only rotates, very little if any lateral movement.
The coupling is designed to take the wear (not hardened and tempered like the shaft. I just replaced one of mine. It's 60 bucks at the dealer and takes about 20 minutes to replace.
sheepfarmer
Nov 14, 2014
4,444
661
MidMichigan
The B2650 does not have any grease zerks on the drive shaft listed for care in the manual, while my L3560 does have one. There are grease fittings in the rear on the top link and the lifting rod, and one on the speed control pedal linkage. And they recommend the battery terminals too. It is a much shorter list of zerks on the smaller tractor to care for.
