Does MX5400/6000 fuel tank beep when you fill the tank like Grand L does?
flyingbrass
L2350
Feb 6, 2016
54
Arkansas
On my grand L6060 I click the key two positions to the right. I fill up the tank and as it gets full the tank has a beeper that gradually goes to a solid beeeeeeeeep when it is full. Does the new 5400/6000 series do that?
8,770
I have the ROPs model so the ignition switch only has three positions i.e. off, on and start. I haven't tried filling the tank with the ignition in the "on" position but I don' t think there's an audible beep to indicate how full the tank is or else it would beep whenever I started the engine.
The cab model has a four position ignition switch adding an accessory position. I have a JohnDow fuel tank with a nozzle that has an auto shut off feature so I don't need an audible indicator.
Hunter1157
MX 6000 HST Cab, Kubota RTV X1140
Apr 26, 2020
32
21
Palestine, Tx.
I have a MX6000 cab model but to be honest I never have the key on when filling with fuel. Never really thought about leaving the key on while filling it up.
5,444
2,137
None of the MX's had this feature when I left the dealer last year. Grand L feature only to my knowledge.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
255
89
Jefferson, Ohio
I have a L3540HST and a L4060HSTC. They both beep.
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
I have an L3560 rops. It doesn't start to beep immediately, and at first I thought it didn't work. I think it has to be up to a certain level to start and then the frequency increases until solid beeeeep. The fuel pump is ticking away all the while, and perhaps it is helping to equalize the volume in the two parts of the tank.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
448
238
Randolph county N.C.
I am embarrassed to say I own a 4760 and have no idea if my tractor will beep when filling the fuel. I have overfilled the fuel almost every time I top it off, and said bad things about the engineer that placed the fuel fill at the level that they did. I hope it will work.
flyingbrass
L2350
Feb 6, 2016
54
Arkansas
turn key 2 clicks to the right
8,770
Key on my open cab 4760 only has 1 click to the right then crank. I can here fuel pump running so maybe it will beep while filling.
How would the tractor know when you're filling the fuel tank? Surely you'd hear a beep with the key in the "on" position prior to turning it to the "start" position if it were a feature.
CGMKCM
Jan 26, 2021
448
238
According to my owners manual it is a feature that the Grand L tractors have. How it works? No idea. It is supposed to work with the key in the first position for tractors like mine or in the 2nd position for cab models. I have to wait to burn off fuel before I can test it. Kubots states refill at 1/4 tank and I have been topping off tank constantly.
8,770
I would expect the float in the fuel tank is the most likely way that the tractor knows fuel is being added to the tank. Maybe a circuit is active only when the float position is changing at a rate that is consistent with the tank being filled.
whitetiger
Nov 20, 2011
3,177
1,599
Kansas City, KS
It is a feature only on Grand Ls and KX excavators. It is reading the fuel level sender to warn you so you do not overfill and run fuel on the ground.
mikester
M59 TLB
Oct 21, 2017
3,871
2,518
www.divergentstuff.ca
I wish K would start making tractor fuel tanks and refilling at ground level like some of the other brands. The beep feature sounds like a nice to have option if you have to use gerry cans.
SDT
multiple and various
Apr 15, 2018
3,311
1,101
SE, IN
Bingo.
The fill spout on my M9960 ROPS is behind the seat, very hard to access with 5 gallon cans and mower connected to the hitch.
Cab models have filler in front of left door.
SDT
8,770
Bingo.
SDT
It wasn't a too much trouble to fill the BX tank with 5 gallon cans but when I got the MX with the filler neck up on the hood and a 13 gallon capacity I decided I wasn't going to mess with that any more. My solution was a JohnDow 106 gallon fuel tank with an auto shut-off nozzle. Definitely a really good investment and good enough that I recommended it to a friend with an L who is equally happy with his.
They can be ordered through Home Depot, and if money is tight, there's always the 6 month interest free option to soften the blow. That's what I did and will always do if it's an option.
58-Gallon and 106-Gallon Diesel Carrytank » John Dow
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
The L3560 rops has the fuel fill on the right hand side at "ground" level, about 3 1/2 feet up. Reason I bought it. Wish the B2650 were similar. Depends on whether or not tractor uses gravity flow for fuel supply, even historically.
Hunter1157
Apr 26, 2020
32
21
Palestine, Tx.
I filled my MX6000 this morning and with the key two clicks right there was no beeping at all.
