Does a rear finish mower leave piles of grass?
BigG
Sep 14, 2018
1,951
773
West Central,FL
If you let the grass get too long. Any Mower will clump up.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,381
3,217
PEI Canada
As in wind Rowing? @GP Outdoors has a few vids on his Land Pride unit.
With my 60" MMM with the discharge chute down I find the clippings more noticeable vs raised. I drilled a small hole on the end of mine and use a rubber strap to keep it lifted. From what I have seen of a rear finish mower and my hope for the one I have ordered is that with each blade having its own discharge the clippings are hardly even noticeable.
Pawnee
L2501
Jul 1, 2021
356
321
Ontario Canada
I find it surprisingly good. The side discharge Ford 916B leaves a row from all three blades, the rear discharge FDR1660 spreads the clippings out evenly behind, even if the grass is a bit long.
Elliott in GA
Mar 10, 2021
785
774
North Georgia
My rear discharge finish mower leaves as little clumping/windrows as possible. Of course if you cut high enough grass the cuttings will be visible. I cut a 2.75 acre field every 2-3 weeks, and it looks very good.
