Does a 1995 B7100 hst have a water pump?
northern hunter
b7100hst-d
Mar 2, 2011
32
Becker, Mn
I bought the tractor for $200 no joke! Been getting part together to repair a few things but have not spent alot of time around it yet. I had to store it at the folks place till I made room in my shop and had time to work on it. Runs but needs a good amount of tune up work done on it.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,118
116
Hardisty, Alberta
A 1995 B7100hsd has a conventional water pump The real early B7100hsdt didn't have a water pump ( 1981-82)
northern hunter
b7100hst-d
Mar 2, 2011
32
Becker, Mn
Just found out that there was no water pump on the D750 engine they said that all that series of motors do not have pumps ! Thanks for the help !
eserv
May 27, 2009
2,118
116
Hardisty, Alberta
Yes, you are right! That's what I get from trying to rely on memory! The b7200's have waterpumps, the B7100's do not.
handyman
Kubota B7100HST-E
Sep 18, 2009
452
Dayton,Tn.
Northern hunter I have a B7100 hst make sure you clean and backflush radiator and mix exactly 50/50 green antifreeze and maybe replace cap.I run mine several hours at a time no problem but EVERYTIME I start to use it I check the coolant level. Mine never overheats I have a lazer gun I check the temp with. Handy
bikerdib
L4701 with FEL, BH92 backhoe
Oct 5, 2010
210
14
Wallis, Texas
Also, check and make sure it has the whistle on the end of the overflow tube so it can let you know if it is getting hot. Keep the radiator clean inside AND outside; I used to run my 7100 all day in the summer and it never ran hot.
lahoyer
B7100 and a bunch of attachments
Nov 12, 2010
Danbury,Wisconsin
Some series of the D750 DID have a water pump, but not on Kubota tractor applications. Bobcat used a D750 engine that, did in fact, have a water pump and I believe some reefer trucks use that engine.
northern hunter
b7100hst-d
Mar 2, 2011
32
Becker, Mn
Has anyone used a additive in the coolant ? In our race car we ran water wetter dropped our temps by about 20 degrees at high work load!
