Documents that come with new BX2380?
pgmrdan
88
Am I going to get everything I need with the machine to tell me what/when I need to do service/maintenance?
Any extra documentation I should get right off the bat or shortly after receiving the machine?
Before arrival I'd like to have the correct grease for the gun if something special is needed. Anything special?
How about other fluids and lubricants that I should get now?
Just getting prepared.
Thanks.
jmf78
BX23S W/ Factory Deluxe Cab, 60" MMM, 60" BX-2612 Snow Blade & BX-2816 Blower
Nov 5, 2015
437
Edinboro, PA, USA
You'll receive your owners manual which will give you all the service / maintenance information you should need. Leading up to that, you should have no problem finding recommendations on grease, oil, etc... on this fine forum through the search feature.
Sent from my SM-N920V using Tapatalk
imnukensc
BX2380
Sep 10, 2015
619
512
Midlands of SC
Your dealer should also provide you with manuals for any implements you get with the machine---front end loader, mid mount mower, etc.
NewtoOrange
L2501
Mar 1, 2017
50
Pleasant Plains, Il. USA
That will depend on the dealer. When I got my L2501 in December the only manual was for the quick hitch and that was only because somebody stuffed it into the toolbox. No manuals no second key. Was told they will be sent. By July I never received anything. Sent an email and dealer said "my bad" will get that stuff to you. Middle of September now and nothing. Did my own 50 hour in July after buying or downloading all the manuals. Found my front axle was 4 quarts low and capacity is 4.6 quarts. Make sure you tell them to get you all manuals and prep the machine especially fluids prior to taking possession.
pgmrdan
88
I found the shop manual for the BXxx70 series and downloaded it.
Haven't found recommendations here for fluids, grease, etc. but I'll keep looking.
Thanks.
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
As part of the purchase deal, I would ask for the full workshop manuals for the tractor and implements
rkidd
Dec 7, 2015
743
67
Jefferson Ohio
I second this idea. When I got my New B2650, I ordered the WSM, and we ended up spitting the cost which was fair enough to me.
jmf78
Nov 5, 2015
437
Edinboro, PA, USA
