dismounting is not a failure
6,964
Very nice job, Ray!
Sent from my QTASUN1 using Tapatalk
6,741
Ray, don't let your neighbors find out you did the welding because they'll be hounding you forever to fix everything that breaks. Nice job. Good looking welds and paint job to.
3,108
Those welds look great! I'm jealous, because I'm pretty sure you've been welding for a lot less time than me, and my welds don't look that good. :eek:
My excuse is that I always worked with NASA certified welders, so anything I needed welded, I just turned over to the experts.
CaveCreekRay
Jul 11, 2014
2,631
105
Cave Creek, AZ
Thanks! Truth be known, I have adopted Frank's adage: If you can't weld good, weld lots. What I am really good at is grinding. :)
I did it outside and the wind picked up towards the end. MIG welding never works as well in the wind. I need to make a wind break. That's another project.
6,741
An old appliance box works good for a wind break. Just break it down and use it for wind break, shop floor protector, low level creeper.
But to keep on topic, now you don't need to get off your tractor as much?
CaveCreekRay
Jul 11, 2014
2,631
105
Cave Creek, AZ
GREAT idea Len.
I was hauling more branches to the dumpster today. On-Off-On-Off time 50. Why is getting on and off a machine so dang exhausting? It can't be because were too heavy. Muscle just weighs so much more than fat!
CaveCreekRay
Jul 11, 2014
2,631
105
Cave Creek, AZ
Hadda dismount for this one... Ocotillo down from last weeks storm. Probably 400lbs. 50/50 chance it will make it.
See all the dry weeds? Globe chamomile. Not native to AZ. Appeared all over my area last Spring. Impervious to Roundup.
4,150
Are you sure you are even allowed to try to make it better?
CaveCreekRay
Jul 11, 2014
2,631
105
Cave Creek, AZ
I hand picked over 500 small bushes (burr sage) across two acres getting ready to try and spread seed from some nicer bushes and plants in the Spring. Everywhere I opened up, the chamomile moved in. This winter I have to spray a few gallons of pre-emergent to try and control the chamomile but that will also prevent germination of the plants I want started. It may be a losing battle now. What I REALLY need is a slow-moving smoldering grass fire to burn up most of the seeds.
