digging in clay
yankeepac
L3200
Apr 4, 2013
62
salisbury nc usa
Have been having a terrible time digging post holes with my post hole digger. It works great when in the dirt, but when it hits clay (north Carolina has lots of it), it quickly bottoms out, and isn't able to screw in further. I have had to dig by hand most of them, and the back is getting pretty tired. any ideas?
Tooljunkie
May 13, 2014
4,150
Did this with a gas auger years ago, hardpan it what sone call it. Auger would stop, and when lifting it out of hole it would be hot. Look down and see your reflection in what looked like a ceramic bowl..
Pour in a couple quarts of water, let it soak in and try augering again.
8,742
You can get a down pressure kit to help break the barrier. ;)
yankeepac
L3200
Apr 4, 2013
62
salisbury nc usa
I love the everything attachments video's Especially peanut, does what he wants to, not what he is told to do.
looking at their augers, it appears the tips are a lot more aggressive. More cork screw in shape. Is this something that is replaceable? Is it a standard size? where would I get this. My auger I believe is a land pride. Made for John Deere.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
I have 16 acres of shale, not land. My gas powered 6" is mostly a drill bit I attack at varying angles with. Pick-ax and shovel share the work. I had a neighbor blast 24" holes for my Porch sonotubes. 70hp skidsteer was nearly spinning around the auger bit. It had aggressive teeth down on the point and he was grinding those things into nubs after 3rd hole. Ive never personally dug deeper than 16" trench on my land. I dig as deep as I can for Norway Spruce root-balls and berm dirt around them...
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
The fill with water overnight usually worked for us. If you're rushed, you can use digger poles and sledgehammers. If you're really, really rushed, ammonium nitrate fertilizer and diesel fuel... :D
