Diesel leak M6030
farmer6255
M6030
Mar 13, 2020
Winnejup, Australia
Hello all,
New owner here, just picked up a 1990 M6030 yesterday. After driving it home I noticed a small diesel leak on the side of the diesel filter, attached photos of where I think the leak is. Overnight I collected a 100-200 mL into a container so doesnt seem like a large leak or possibly this is just all that could flow out of the system.
Is the leak coming from a perished gasket, and if so can anyone provide some guidance on the part I am looking for to replace?
Thanks
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,057
Williamstown Ontario Canada
As a start I suggest you replace the copper washers on the banjo style fitting.
GASKET, COPPER 15471-96650 $1.62 each two needed.
These washers should be replaced or annealed every time the fitting is touched.
The copper washer hardens when the fitting is tightened and when reused cannot conform to the small imperfections it is intended to seal.
Automotive supply places likely have a suitable washer.
Dave
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
You can try simply tightening the bolt a bit - don't break it!! If you wish you can try annealing the existing washers and perhaps save a trip to the auto shop. If you buy new washers be sure they're copper, not steel. Steel is too hard and won't conform.
thepumpguysc
267
Sunny South Carolina
As suggested, replace the washers.. in the meantime, turn off the fuel at the tank..
If u look at the "path".. that fuel has to travel up/down thru the supply pump.. not good, that supply pump should only allow fuel to flow thru when running..
The valves in the s.p. may be bad also.??
Thats what it looks like to me anyway..
If AFTER u replace the 2 inlet washers & u find that its leaking from the large washer BELOW the other 2.. let me know, I have some..
SidecarFlip
Banned
563
Since when did Kubota use a Stanadyne style rotary pump?
3,084
What is in the pan looks like antifreeze not diesel to me. Might be just the way it shows in the picture but just verify you are chasing the correct system.
7,650
Russell, he's in Australia and they may not dye their off road fuel. I thought the same (about antifreeze) when I saw the picture.
farmer6255
M6030
Mar 13, 2020
Winnejup, Australia
Thanks for the responses everyone, I'll get some new copper washers first and see if that seals it up. Is there a torque I should use with a torque wrench when tightening, or just tighten to feel?
Yes it's definitely diesel, here in Western Australia our diesel is that colour.
thepumpguysc
267
Just feel.. as far as I know..
Dont forget, if u tighten the snot otta it, theres no more "crush".. so go snug & check it.. U can always go more..
I just saw your location.. I guess that rules out me sending u that pump copper gasket.. lol
SidecarFlip
Banned
563
Very easy to soften work hardened copper sealing washers. To 'anneal' (soften them, heat them to red hot and allow them to cool. I use the wife's stove top electric element, just lay the washers on the element, turn it on, let it get it get red hot and turn it off and let it cool. Presto, soft again.
3,084
I hadn’t bothered to look at your location and even if I had I did not know that diesel was any other color except here in the USA it is dyed red if sold for off road (less tax) use.
Is that the Australian regular or off road (if you have that) color?
farmer6255
M6030
Mar 13, 2020
Winnejup, Australia
Hi All,
Just an update on the resolution for this one. In the end it was a small crack in the fuel delivery line from the diesel filter to the injection pump. A previous owner had tried to do a dodgy repair with epoxy and it was flaking off. My neighbor and I removed the line, had it brazed up, and now shes all good.
