D1105 question
OlFerguson
4440, 1120D
Jun 1, 2017
183
11
When your cleaning your breather tube , breather valve etc what do you use for a cleaner?just some air or ? I haven’t really found how to clean in the WSM. Still learning. Thanks
5,130
Yes sir. Just trying to prevent issues with my crank seals again .
If your taking the line off, brake parts cleaner, if your leaving it on just air, but never through a valve as you'll blow out the diaphragm.
So basically, you don't really ever do anything to them, but if you want to disassemble it and clean it, go ahead.
I would use anything on the valve, and water is the issue with the valves malfunctioning not oil, so a little oil in there won't hurt anything.
OlFerguson
4440, 1120D
Jun 1, 2017
183
11
Thank you
