Cutting edge bolts
dlsmith
BX2230, LA211
Nov 15, 2018
1,360
1,060
Goshen, IN
On my BX, I just cut the bolts off flush with the top of the nuts.
Of course, it depends on what type of materials you handle with the bucket, as some materials might get hung up on the bolts, but dirt, gravel and snow, not so much. IMG_20200202_124329073 (Custom).jpg
3,057
Should I cut these off or let them stick up??
Those are lock washers and 3/8 - 16 nuts? I'd sub out the standard nuts , replace with low profile nylon insert nuts AND then cut them off! ;)
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
I tapped the wear edge and ran the bolts in from the top. After things were tightened down, I ground the bolts off flush with the bottom of the bar. The bolt heads don't stick up very far. IMG_4594.JPG
4,193
All-Metal stop nuts (instead of nylon) would be my preference if you don’t simply cut them off flush and (stir-weld) them (flush.)
