CUT for timber clearing, plowing, grading
Whitemike
17
Idaho
Im looking to get a kubota CUT to help maintain my timbered property and to plow my dirveway. I also have about a 300 foot gravel driveway that id like to be able to maintain and grade at some point but my main focus is on the timber and snow removal to start off. I live in Idaho and winters are long so snow removal is important. I have 7.5 acres of timber. A LOT of it needs to be thinned/removed. There is a bit of mature timber that I want to leave alone but there is a lot of immature re-prod that is tightly packed and needs to be taken care of. The trees in question are 20 feet tall or less and 10 inch diameter or less, with the majority of it being 10ish feet tall and about 6 inch diameter or less. Along with that ill have never ending slash/burn piles while trying to maintain a healthy lot of timber. Rather than renting a mini ex every weekend indefinitely id like to just own something and do it at my own leisure which is why I'm considering a backhoe attachment on a CUT. I realize a backhoe is not the best tool for the job but when i cut down these smaller trees id like to dig out these smaller stumps too. Is a CUT with a backhoe going to be a good tool to have? only 1/2 acre of my property is grass so i am not considering using it to mow. What model should i look into? My budget is to keep it around 30k max, preferably under but going over is not out of the question.
Thanks
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,178
1,167
E.
lots of options however I avoid the what is better discussions. (ford or chevy, UDT or SUDT or other, etc...)
However word of advice from a guy that has for decades done what you are proposing very succesfully. I use a L with back hoe, grapple 8 1/2 tonne logging winch, etc... alot..
1. under armour whatever cut you get. stick pokes through rubber boots, hooking hoses, poking rad's, rad fans destruction, etc... is expensive and adds up quick. Custom under armour as off the shelf stuff rarely exists is going to be a huge savings in the long run. I have yet to see a cut with any way near enough brush protection to venture into what you propose. So if you intend to use off field or off road this is a must IMHO
2. backhoe on CUT works fine just do not expect the same amount of work as a mini ex. / hr can do as a cut is often 1/4 of the weight. once you get really good you will still be less than 1/2 productivity of a mini ex. Rookies can expect 1/4 productivity as your finesse will need to build on how to cut roots, under dig, etc... I do about 4 to 5 10" rnd pine stumps / hr with a BH77 backhoe
good luck... I love brush work with my Kubota L.
Elliott in GA
Mar 10, 2021
884
895
North Georgia
You might find that a tractor plus grapple and a PTO stump grinder would be more effective and less costly.
Shekkie
LX2610, Virnig 60" Grapple, WoodMaxx TM-86H, Woods 60" BB/72”RB
Feb 12, 2022
183
306
Grafton, Ohio
For a CUT first narrow it down to what size will work best for you. B/LX/L? With a backhoe and FEL you are limited to the B series for $30k-ish…….not limited as in “bad” just limited as in that is the best option to keep to your budget. Without you can get an L/LX with FEL and a grapple then get/rent a stump grinder when convenient if you feel the need.
I am clearing tornado tree devastation with my LX, grapple and Husqvarna chainsaw. The stumps can wait/rot.
radas
Mar 21, 2022
719
834
I'm also a tractor newbie, but based on what you're looking to do, an L/LX seems like the best idea (with the LX being a bit more maneuverable in the tighter areas at the expense of slightly reduced FEL capacity and torque). Get a grapple ($2-3k) and a PTO stump grinder (can be had for $2-3k) and will make short work of things.
Whitemike
17
Idaho
Thanks for everyone’s input. After doing more research I see that the 30k isn’t really reasonable for what I want so I’ll be looking in the 40k range. GSD-Keegan what model is that in your picture? Are you able to pick up logs that size and transport them to another area?
Shekkie
Feb 12, 2022
183
306
Grafton, Ohio
For reference this is about the max for an LX to lift/move.
BobInSD
L5740
Jun 23, 2020
374
129
South Dakota
I realize that this is a tractor forum, but have you considered buying a (used) mini-ex to whip the property into shape, then selling it and buying a CUT for the maintenance chores? I don't know about today's market, but would think you could get most of your money back when you were done with it
bbxlr8
Mar 29, 2021
455
314
Eastern PA
I am squarely in your target use case except most of my trees are larger. I went L2501 TLB with 3rd fx and grapple after much advice here and pros/cons considerations. I am a year in and have moved about 30T or deadfall in a two-week period last summer. I have dug much larger stumps (had 20 mature blow-down oaks from Hurricane Sandy - some more difficult than others) and think your needs from your descriptions should be fine. I use the grapple for clearing and firewood processing. I also had grading, rock, and digging considerations that made this a good choice for me. Check out some of my previous posts.
I am not using much PTO or ground pulling power so the 2501 and no EPA was a plus, not a minus power-wise as the hydraulic pump is the same except for the 4701.
I think this level & combo prob. should be on your shortlist but there are a lot of considerations in your world that only you know... :)
edit: Oh, and a BB was a must-have afterward - you may want to consider that for the gravel drive.
nbryan
Jan 3, 2019
1,430
948
Hadashville, Manitoba, Canada
Thanks
Check out my equipment list in my signature. I'm running it on 116 acres mostly forest and bush.
Couldn't be happier.
top gnome
Dec 12, 2021
461
220
Fundy shore nova scotia
I second the grapple
Where do you get the under armour?
I second the grapple fairly new at it but it really makes quick work of moving brush limbs and logs.
MapleLeafFarmer
Dec 2, 2019
1,178
1,167
E.
I make my own out of UHMW (Ultra High Molecular Weight) plastic sheets I get from my local farm supply store. Easy to work with, flexible, cuts with jig saw, easy to make cut-out/holes, etc...
I know there are some companies making them for the BX/B tractors due to the very low ground clearances, bad fan design, and how people often use these machines as off-road mini work horses. For my latest L I just made a 2 piece thingy myself in an afternoon.
edit: I use can am style skid plate cup washers to mount to homemade cross members that get pinched in place.
bbxlr8
Mar 29, 2021
455
314
Eastern PA
Sounds like a creative and effective solution. Do you have any pics? :cool:
top gnome
Dec 12, 2021
461
220
thank you I noticed right away the little b are close the ground. the uhmw is a good idea I will have to look at that are you using 1/4" or thicker. I do not have many metal working tools but I have a old iron wood shop.
MapleLeafFarmer
Dec 2, 2019
1,178
1,167
E.
I use 3/8 cause its what is available on the shelf in 4*8' sheets.
I attach to cross channels I make out of angle iron and use can am style skid plate washers. I use bolts of varying lengths with nylok nuts. I bend with heat gun to create wings for attaching
No need for welder or metal working equipment. A drill with various sized bits, hole saw for wood makes nice round holes, and jig saw all I needed. Will get pictures next trip to my shop.
washers cheap and keep bolt heads up higher so bottom stays smooth and catch free over brush, etc..
1648325529180.png this way bottom of skid plate very smooth. I drill / cut openings to access, drain, etc... These plastic sheets can be cut on a table saw, with jig saw, can be bent by heating with paint stripping gun, etc... It can be shaped with heat just don't over heat.
I make templates out of cardboard first then trace onto the sheet of plastic and cut (cut slowly) so not to make too much heat.
BXpanded makes out of metal for the BX if thats what you have for a tractor
Whitemike
17
Idaho
I just returned from the shop and it’s looking like I’m going with an L 3901. There is a 3902 for I think 2500 more and From what I remember it was just convenience and comfort differences, not performance. Thoughts on 3901 vs 3902? Now I just need to weigh if the 11,000$ backhoe is worth it
Whitemike
17
Idaho
Now I’m actually wondering if the 3901 would be overkill for what I need. There is a long list of people waiting for 2501s so I wouldn’t have one until the end of the year so we didn’t talk much about the 2501s unfortunately, just the different attachments available and what I would need
top gnome
Dec 12, 2021
461
220
View attachment 77162 this way bottom of skid plate very smooth. I drill / cut openings to access, drain, etc... These plastic sheets can be cut on a table saw, with jig saw, can be bent by heating with paint stripping gun, etc... It can be shaped with heat just don't over heat.
View attachment 77163 View attachment 77164
thank you that looks great
top gnome
Dec 12, 2021
461
220
I would have preferred the l2501 but the wait negated it for me.
bbxlr8
Mar 29, 2021
455
314
Eastern PA
Prob the right ballpark for your needs and you won't be sad with more capability or tractor
It's available (repeat IT"S AVAILABLE)
Dive into the specs:
  • Same frame (weight)
  • Same hyd pump.
  • More HP for ground pulling
  • You will have EPA & Regen but "so what" in the long run. They are pretty well sorted and a fact of life at that HP
Costs more but like I said in my orig. post only you can make the call in your world
Q: Have you bracketed tractors just under L series and tried those in a 100 m radius? (realize that may not get you anywhere in Idaho ;))
edit - a lot of people will say the BH is not worth it but NOT ME. I love mine & use it all the time. I would never do all of the additional projects that I have found if I had to rent.
