Creep
Stmar
B2650HSDC
May 23, 2017
906
42
Buffalo, Wyoming
B2650HSDC is starting to creep a bit with the brake on. Is this a brake issue or hydro? Not too bad yet but thought I would get some input before I started adjusting stuff. I keep the pedal linkage greased, have never adjusted the brake.
sheepfarmer
Nov 14, 2014
4,444
661
MidMichigan
Hydro pedal etc. Look for thread by eipo. His crept right out of the barn.
eipo
L4060
Dec 1, 2015
693
81
MI
Pull the plastic cover at your feet and youll find the hydro pedal linkage on the same side as the pedal. Whats happening is the shaft the linkage rotates on is binding. It needs to be lubricated. PB blaster seems to work, but it needs to be reapplied frequently. The best solution would be to pull the linkage and drill/tap to install a grease zerk.
eipo
L4060
Dec 1, 2015
693
81
MI
Here is the thread...
Mark_BX25D
Bx25D
Jul 19, 2020
1,611
1,140
PB Blaster is not intended for lubrication. It's a penetrating oil. That's like using a wrench for a hammer. Yeah, you can use it, and it will do some lubricating, but not well and not for long.
eipo
L4060
Dec 1, 2015
693
81
MI
Yes, but the area that needs lubrication has no means of accepting it. Hence the need for something that creeps.
Mark_BX25D
Bx25D
Jul 19, 2020
1,611
1,140
Try Fluid Film. Not a penetrating oil, per se, but it does penetrate (slowly), but it won't evaporate quickly.
eipo
L4060
Dec 1, 2015
693
81
MI
FF creeping properties would be ideal in this situation... If I still had the tractor......
The PB, and Im not advocating the PB being a long term solution, did free it up almost immediately. Had I kept the 2650, I would have drilled and tapped the offending linkage so it could be greased.
