Will it start by shorting out the solenoid terminals using a screw driver with the ignition on?Bx24 Fuel pump is not working replaced pump still the same thing , Is there any safety switches that will shut fuel pump off ,
Yes a 15 amp fuse.Everything is good ,just the fuel pump does not run , I have a little hydraulic leak and i was wondering if there was a safety switch on the fluid level .or is there a fuse for the fuel pump ?
Likely right side of tractor inside the screen enclosure for the battery. Would be right about where your right knee is when driving it. (that's where my BX2360 is)where is it located
I pulled all of them last night and they all look goodLikely right side of tractor inside the screen enclosure for the battery. Would be right about where your right knee is when driving it. (that's where my BX2360 is)
Parts diagrams -
Kubota Tractor Corporation - Illustrated Parts List
- K-PAD - Parts Lists - Illustrated Parts Lists - diagramsapps.kubotausa.com
Try here for an operator's or Workshop Manual (WSM).
www.kubotabooks.com
