Cost of 1 11MM Nut
ttfo
B7100 HST, RTV 900
Oct 3, 2012
54
Custer, SD
I am rebuilding a b7100HST. When I ordered new 12 Head bolts,2 studs and 2 nuts for the studs for this engine, The head bolts and studs were in reason, but the 11MM nuts were $23.00 EACH.
At first I thought it was a mistake and called 2 Kubota dealers and they said that is the correct price, but they were not sure why.
Has anyone ever purchased one of these?
4,039
Sounds like a trip to Lowes is in order, I have found lots of fasteners in the drawers fill with all kinds of silly stuff, or off to maybe auto parts store 23.00 bucks man that has got to be a typo
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
Leafy England....
Yes i'm afraid you are correct, they are 11mm .
I had to purchase some last year for my 7100 (750 to 850 rebuild) and they were not cheap here in the UK either:eek:
Not sure they worked out as much as yours but still way more than a 10mm or 12mm item of the same spec.
Its a mad size to be honest, and just another way of ensuring people have to buy genuine Kubota parts a guess.
rob.
ThisIsNotaStep
2005 bx23 tlb
Nov 26, 2010
133
Ontario, Canada
sometimes they are pricey, but you have no choice, dust cap for bottom of spindle on mower was $35, tuna can was a perfect replica and the tuna wasn't too bad!
4,039
Are you sure you wasn't in my local Harley dealership?
davemskinner
Sold ZD28F, Bought04 Grnd L4330 /frnt mnt snwblwer L2185, hted/AC cab, 2nd ZD28F
Mar 12, 2011
96
Pulaski, NY
I sent a email to Kubota. They are checking into it.
It'll be interesting to see what they have to say! Sometimes I begin to wonder it is worth it to spend the big bucks for the quality machines because parts are soooo expensive. :(
ttfo
B7100 HST, RTV 900
Oct 3, 2012
54
Custer, SD
This is the response I got from Kubota:
The price of the nut has been lowered to $11.44 list. The answer from our parent company about this nut was that they'd never bothered to try another vendor and so all of the price changes over the years affected it, as well as the fact that it is a special nut anyway, due to it's application.
Thanks very much for pointing this out, I hope this is a little better.
Regards,
Ben Hester
Parts Manager
Kubota Tractor Corporation
Northern Division
78-79fordman
2013 m7040hd 2013 L3800HST 1969 MF135
May 21, 2013
255
Gillham Ar.
Local parts store has this size nuts for a dollar or less each . Sounds like I need to be Kubota's a new vendor .
Sent from my iPhone 5 using Tapatalk 2
hodge
Nov 19, 2010
2,950
514
Love, VA
Special fasteners cost a fortune- it isn't just Kubota. I bet you won't find that nut anywhere. but Kubota. You might find something that will do, but not that nut.
I bought an overflow valve for my Cummins. It is a hollowed out bolt with a spring and ball inside. $109.00. I could have gotten it for less, but not right away, and not made by Bosch. I was in the middle of diagnosing a problem, and needed the factory overflow valve. So, I paid dearly because it is a specialty item, and because I had to have it.
ttfo
B7100 HST, RTV 900
Oct 3, 2012
54
Custer, SD
I did get a reply, from Kubota on why the price was so high, mainly because these nuts are for older tractors and they do not stock many.
Anyway, I did order the 2 of the $11.00 nuts and when I got them they were USED!!!
I sent another email, but have not got a reply.
4,039
Where did you send to for the nuts 22.00 bucks for used nuts,, man that's crazy, you could have had them machined for that much
Burt
L3700SU, box blade, 6 foot rhino blade, 1 bottom plow, 3 point receiver hitch.
Mar 24, 2012
337
Goldendale, WA USA
Great research and response regarding your nut case.
Many of the bolts and nuts on these tractors are also a specially marked alloy I noticed.
The sizes are also part of the nut program, however, in order to deal with it, all over my tractor, I wrote the nut size in black permanent marker so if I ever have to loosen or tighten them, I'll know the right MM wrench size to get.
Never give up!
Burt
Battered Sav
L2000DT (L225DT) Tiller, Slasher, Finishing mower, Ripper, grader/ripper, PHD.
Oct 1, 2012
65
Melbourne Australia
For some reason Kubota use metric 'fine' threads, even in a metric country (Australia) these fasteners are unusual and expensive.
