Considering adding rear tire ballast
Whiskey Papa
B2920
Sep 21, 2013
23
Illinois
I need to add some rear weight to my B2920. It sounds like the common (safe) choices are beet juice or poly-glycol anti-freeze (pink non-toxic stuff). I was wondering if motor oil or hydraulic fluid would work. It must certainly be heavier than beet juice and would actually help stop rusting. I just wonder if it would work its way through the tire bead since oil likes to penetrate. Any thoughts on used motor oil? That stuff is free.
If oil is a viable option, I suppose one would need a way to get the oil into the tire. That might be a little more tricky than a standard submersible pump...
MtnViewRanch
719
176
Lakeside Ca.
Beet juice is the way to go if it is available in your area. ;)
◾Calcium Chloride is heavy – about 11.5 lbs./gallon. Rim Guard™ weights 10.7-11 lbs. per gallon – about the same.
◾Calcium Chloride is freeze resistant to -30°F or -40°F depending upon how it is mixed. Rim Guard™ is freeze resistant to -35°F and will not solidify until -50°F.
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
If it were me I would do the beet juice.
There must be some issues with using oil, especially used oil. Can you imagine trying to do a tire repair after oil soaking the tire& rim.
5,298
Motor oil will soften the rubber.
hydraulic fluid might work,but cost of it would be huge, without much gain.
I wouldn't want to ever have to change a tire!:eek:
What would you do to fix a flat???:rolleyes:
Sung in the Beverly Hillbillies tune!
One day why rolling along harvesting some food a stick come along and look bubbling crude!:D
