Connecting PTO to Tractor - ? on Plastic Shields
wendol
L3800 HST
Feb 5, 2014
194
40
North Tx
I have been having trouble extending/connecting the PTO shaft on my brush hog (Woods - BB72X), and finish mower (Woods - PRD7200).. I followed some of the suggestions on how to properly clean and lube the inner/outer metal shafts, and that really helped in that area.
However once reassembled, I discovered that most of my problem was, and remains, the resistance between the inner/outer plastic shields as they telescope in and out. Is there any solution to make this telescope smoothly?
Your thoughts and suggestions would really be appreciated.
6,808
Try Fluid Film. Doesn't attract dirt/crud, etc.
I get it at Lowes.
jajiu
Jun 5, 2016
456
Rowley, Massachusetts
Kubota dealers sell it as well, that's what they use on the pins etc. More money than Lowe's, I bought several cans on line (ebay) for cheap money.
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
I use silicone spray where dust, dirt, etc. are present. It works great and little cheaper than fluid film which I also use.
I have 2 sliding compound miter saws and I even use it on the slide rails and even the fine saw dust does not stick to the rails.
Good luck
SidecarFlip
Banned
557
I was wonder where to get Fluid Film. I keep hearing about it, but have never seen it anywhere. Thanks... helpful that you gave a source.
Amazon has it is all quantities from spray to gallon cans,
