Concrete Curing?
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
The floor of my new barn is 8 days old.
It's 4" with fiber and rebar. We back the base with AB3 gravel. The concrete guys came and left without me ever seeing them ( they did a great job from what I can tell ). Anyway, I hear 7, 14 or 28 days before bringing in a truck / tractor.
Can anyone set me straight?
2,914
Concrete gets to 70% hardness after 7 days ............... and it never really gets to 100% ;)
The weight of the truck/tractor should be the determining factor.
3-5 days for a car to park on it - depending on weather and cure temps
BX23-S,57 A-C D-14,
5,913
usually they come back NEXT DAY to cut the 'joints' while it's 'soft', don't wait a week.
After a week most vehicles can be parked on it, but avoid big tractors and forklifts.....
mikester
M59 TLB
Oct 21, 2017
3,964
2,645
www.divergentstuff.ca
I'd wait 30 days before loading the concrete and parking heavy stuff. You can do it now but it sucks if you get spalls and oil spots from grease drips on your brand new floor...especially if it's a polished finish.
Enjoy your new barn!
5,185
Spray on (as in garden sprayer) a good quality concrete sealer, before putting anything on the floor!
It will make it much easier to clean the floor from future stains etc.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
654
649
Indiana
My barn floor was concreted with fiber this morning. The company owner said wait 24 hours to walk on it, 7 days to park the tractor on it.
Njtool
Lx2610 HSDC. BH77 backhoe
Jan 1, 2021
216
282
New jersey
I’ve poured garage and shed floors etc. 90% strength at 14 days, someone posted a graph.
If it were mine, I would wait until I could use epoxy on the floor, I think it has to cure 28 days.
If you wanted to go an easier route, you could find sodium silicate to seal the concrete
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
Depends on the concrete. Did they spray a sealant to cure or are you spraying water several times a day or did they cover with plastic? Or did they just pour and walk away? My recent project I used the 5000 lb quickrete. It gets stronger quicker, but still says 28 days for curing. I went 10" deep so I'll be giving it the full 28 days, spraying with water 3 times a day for the first 7 days, no sealant, no plastic.
I didn't look to see what tractor you have of if the rears are filled or not, that could make a difference. Either way, I'd play it save and wait, not worth rushing it and having to deal with cracks later. Good luck with the project, sounds like it's coming along nicely.
LarryBud
L3130
Dec 5, 2020
252
132
Cleveland, MO
I'll go with poured it, smoothed it out, cut joints the next day and that's it. It's still empty and I can do whatever is appropriate at this time. Lot's of work ( fun work ) ahead.
5,185
Suggestions for a good sealer?
It has been years since I have done any concrete sealing.
If you research concrete sealers on Google, I am certain that you will come up with some good options.
Steamer Pete
LX2610
Mar 29, 2021
49
42
Holland, MI
There's a lot of moisture coming off concrete as it cures. Caution as you park stuff in there more prone to rusting for a while. And keep the doors open to keep moisture from building up.
DaveFromMi
L3901 RCR1260
Apr 14, 2021
654
649
Indiana
I used a sealer, probably the same as below 3 days after the concrete was poured. I read that using a sealer traps water in the concrete longer making it possible to achieve >100% strength over the course of a month.
7,215
Tracktor is a heavy machine, so you better park it on it after two weeks of making the set. That way, you’ll be completely safe. I see no reason to wait until 28 days because you can do it much earlier.
It's been longer than that since the last post. Concrete is probably already set well enough for a tractor! ;)
3,706
I put a lawn water-sprinkler on my hangar-slab,for two weeks….timed to keep it wet for a week…and waited the full 28 days before constructing the hangar onto it.
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
Best way to cure it is cloth clovering, wet it and put a plastic cover over it. The longer you can do that the better. Problem is the surface likes to dry first, that causes it to stop curing, shrink and possibly crack while it's still soft. Secondary fiber reinforcement which is done with tiny fibers will wick water to the surface which works to keep the surface from drying out. It doesn't really do anything after the first 24hrs when the concrete gets hard.
Ridger
L3940 HST
Nov 26, 2014
156
North LA
I had a concrete slab poured for my shop a little over a year ago. The concrete company told me to wait at least 28 days before putting anything heavy on it (truck, tractor, etc.). I sealed my concrete with penetrating sealers from the company below. So far, it has held up well.
