clutch slipping
Shawn396
L2650
Aug 6, 2014
Northville,MI
I have a kabota L2650 not sure how old it is. I put hydraulic fluid in it and I believe I over filled it. Now the clutch is slipping. Can the fluid get to the clutch? If so is it ruined??
5,285
Your tractor is a 1990 to 1993.
If you want a OP and service manual for it give me a shout I have both.
What model do you have a DT, a DT-GST, or a DT-WET ?
If you don't know, what letter logo's are on the tractor.
They all have specific problems with overfilling the case.
Was the case low or empty?
Did you drain it back to where it should be?
Is it leaking hydraulic fluid from under the bell housing?
In the picture is the bell housing drain (yellow) it will look like a nut with a pin hanging out of it, pull that drain out and see if there is any fluid in there.
Shawn396
L2650
Aug 6, 2014
Northville,MI
Thank you for your reply. I'm not sure about the logo I will get back to you on that. I am very interested in the manuals you have also! I will do what you said when I get home, I'm at work right now. Hopefully I'll have answers to your questions also! Thanks again!
5,285
Send me a PM of your email address and I'll send you a copy of the manual. ;)
