Clutch replacement
Deweym3088
3901 Kubota
Jun 5, 2026
Gaston SC
I just split my Kubota 3901 at only 224 hours. Maybe I’m just a bad operator. Not sure. Finally figured out the front driveshaft removal and drove out the front roll pin. When I split the tractor the drive shaft came out of the back splines. I did mark the the front of the shaft but not sure if the back end has moved or not and what to do about it if it did move. Also went with a clutch pack from Kentucky clutch for around 700 dollars. Couldn’t see going the 2200 + at the dealership. Welcome all input/advice. Thank you!
