Canopy for B2650
2650fan
B2650TLB
Jun 28, 2022
65
CT
Wondering what my options are for a canopy for B2650…most importantly cannot add more than 4” in height to ROPS…any ideas and thanks
Jasper2018
Kubota L3130. LA723 FEL, L3901 HST, LA525, bush hog rotary cutter,
May 25, 2021
49
22
Florida
Try getting ahold of a golf cart roof. Most golf cart places do the upgrading with accessories. I picked up mine for $50. Now I just need time to make the mounting brackets
Bmbbm
Bx2370 land pride box blade 60"mmm kubota fel
May 29, 2016
282
Chillicothe mo
I have a Rhinohyde. It's flexible plastic so it wil take lots of abuse and can be mounted above or below your rops.
B737
LX3310
Jun 9, 2019
2,022
2,205
you need a rhinohide.
TractorTime
United States
I just ordered a Rhino Hide for my B2601 and also threw in the extra mounting hardware for reversing it over my backhoe. I ordered it direct from rhinohidecanopies.com with coupon code GWT for 5% off.
It hasn't arrived yet, but I'll give you my impressions once installed. Looking forward to getting out of the sun, but I also need to trim some low hanging branches before I whack them with the canopy! :oops:
edritchey
2026 Kubota T2290-48 2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75
Jul 19, 2014
1,181
950
Wellsville, PA
I have a couple of these on my tractors and zero turn mowers and they are awesome.
2650fan
B2650TLB
Jun 28, 2022
65
CT
My solution was finding a used canopy from a Branson tractor for $150.00 and 2 cans of rattle paint, voila canopy on tractor. Is a steel top and it fit perfectly
E2F4AD80-45F7-4EB6-A7BE-864740BF962C.jpeg and some eye candy
7,532
If you want to be frugal and build your own canopy bend some 1" conduit to the shape you want. Put some bracket on it to clamp to ROPS. Might use a piece of the conduit to come down on the joystick side for support on the front end. Use canvas for the top. Use tie straps to hold canvas.
leveraddict
Apr 1, 2019
905
594
NEPA
You will be surprised the beating the Rhino will take without damage! So my tractor will fit in the garage and I dont have to remove the Rhino everytime this is what I did. Tilt the rops back all the way, now the Rhino is pointed to the sky. Pull the pins and drop it to level, drilled extra hole for pins and walla. Top is lowered, still horizontal and could be used folded down if you wish. I dont use it like that, but its just for getting in the garage!
