can i run a hydraulic motor of the B7001 system?
JosephGozo
Kubota B7001 + an ever growing list of attachments (restored / homemade) :(
Nov 25, 2014
Malta
i am aware the pump of the tractor has a 3gpm rating and maybe small.
Can i run a hydraulic motor (to drive a 100cm drum mower on the front of the tractor) off the tractor hydraulics? I do have a spool valve "T-ed" in the system to operate the baler system. gearbox is filled up with 80w90 oil. i know it is thick.
regards
joe
majorwager
MX5100 FEL ford 1620 FEL International 484 FEL Lull 844C
Never seen a hydraulically operated drum mower ?
Who manufacturers this mower?
Is it still in production? Is there a spec or OM available to determine hydraulic requirements??
What is cubic inch displacement of main drive motor? Make and model # of hydraulic motor?
What is cutting width of mower, 100 cm is cutting or overall width? How will mower be raised and lowered?
EDIT: NIH is correct about the heat factor but you could employ an external cooler, but in all honesty you just lack enough flow as he stated. A PTO pump might work but the mower and a reservoir must share the 3 point linkage.Not clear how implement would be front mounted?? Still curious who produced a hydraulic drum mower.
5,129
Very highly unlikely, the gpm is way too low for just about every motor made that I know of. ;)
Another issue is cooling of the hydraulic fluid, the B7001 does not have any way to cool the fluid.
JosephGozo
Nov 25, 2014
Malta
Thanks . It is a BellonMit unit with a 100cm cut. Shaft driven. I loved the thought of having it front driven but i gues i need to stop dreamin.
I would build a three point hitch for the front.
Thought matching a hydraulic motor would save me the hassle of re.routing rear pto to the front. I was not willing to drive it off the engines splined crank.
Joe
