Cab version B2650 will not restart
ZIG40
B2650
Jul 1, 2023
9
Pennsylvania
Hello, I got a cab B2650 I was using for a little bit shut it off for about 15 minutes, went to restart and it will not start up. All the fuses look good. I have lights on the dash you turned the ignition switch to the first accessory, and you hear a clicking under the hood when you go past turn all the way to starter position it just will not crank. I rocked the foot pedal and that did not do anything either. If anybody has any more thoughts greatly appreciate it thank you..
bird dogger
Feb 24, 2019
1,804
1,779
North Dakota
Gear selector in Neutral? PTO selector disengaged? Sitting in seat? It should start.
Another safety switch is the neutral pedal switch (pedal must be in the returned position (between forward/reverse).
With the other selectors in the proper position for starting..... try holding the key in the "start" position and gently rocking the foot pedal in the "forward/reverse" positions. That switch is a common failure point.
bird dogger
Feb 24, 2019
1,804
1,779
North Dakota
You might also try disengaging the seat safety switch (right under the seat on the right side) and jumper the contacts out on the tractor side of the connection.
ZIG40
B2650
Jul 1, 2023
9
Pennsylvania
Yes, I have disconnected the tractor seat and jumped it from day one. Yes I had checked neutral on a gear selector and PTO move that around and yes, I rock the floor pedal. Still nothing.
Orangeglow
2015 BX2370
Jun 19, 2014
423
236
Prescott, Ontario
How old is the battery ? When is the last time you cleaned and tightened both ends of the positive and negative battery cables ? I would start by removing the battery from the tractor, and having it load tested.
ZIG40
B2650
Jul 1, 2023
9
Pennsylvania
It turned out to be the neutral safety switch on the hydrostatic pedal.
Thanks for all your help everyone.
PHPaul
Apr 2, 2015
1,302
1,639
Downeast Maine
www.eastovershoe.com
Safety-Nazi's Look Away!
I got tired of forking out $40 every time that switch failed, so I built a jumper. No problems in several years now...
