BX2816 on a B2601
Spdfreak91
Kubota B2601
Oct 7, 2020
10
Massachusetts
Does anyone have a B2601 with a Bx2816 on it? whats the performance? Do I need the brush guard B tilt #B3412 for the snowblower and loader? the instructions weren't very clear. I cant seem to find any pictures of the K connect attached to the tractor if someone could take a few pics id appreciate it.
Spdfreak91
Kubota B2601
Oct 7, 2020
10
Massachusetts
I got it all together the only thing I cant figure out is how the manual chute crank hand gets attached to the tractor. Anyone have a picture ?
3,849
There is an L bracket that bolts to the tractor and the handle goes through a hole in the bracket. Most people throw them in the trash and opt for the hydraulic turning system. I built my own on my BX22 using a hydraulic motor. That was about 20 years ago before Kubota offered anything other than the hand crank.
Spdfreak91
Kubota B2601
Oct 7, 2020
10
Massachusetts
4,067
so...... the gear on the motor WILL mesh with the chute gear ??
the hydraulic pressure/volume are the same ???
Spdfreak91
Kubota B2601
Oct 7, 2020
10
Massachusetts
thats what i'm trying to get to the bottom of, certainly looks like it, but before i spend 375 im looking for input or someone to sell it to if it doesn't work
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,424
1,243
WestTn/NoMs
Have you considered the electric option(s)? Either power the worm screw or use a cable wrap setup.
Spdfreak91
Kubota B2601
Oct 7, 2020
10
Massachusetts
yeah electric seems hit and miss, the factory kit is $500 I could fabricate is myself for less but i feel for the money id rather have hydraulic
4,067
One 'cheat', is to download the 'parts list' of the unit, often the hydraulic motor will be listed as the make/model from the mfr, or you google the 'part number' to find a cross reference to it.
You could use any $40 'ATV winch' to do the 'lasso the chute' method . Probably the cheapest,cleanest ,easiest way to do it.
Spdfreak91
Kubota B2601
Oct 7, 2020
10
Massachusetts
