E eddiebob Member Lifetime Member Equipment BX2680, JD 40 Mar 23, 2014 217 1 18 67 Poplarville, Mississippi Nov 26, 2017 #1 I'm getting ready to change out the hydraulic fluid in my BX2680 to SUDT-2. How do I manipulate the FEL to get the best results? Thanks, Ed B
Bulldog Well-known member Equipment M 9000 DTC, L 3000 DT Mar 30, 2010 5,440 73 48 Rocky Face, Georgia Nov 26, 2017 #2 Just set it flat on the ground.
1 100 td Active member Equipment B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat Aug 29, 2015 1,776 8 38 ɹǝpunuʍop Nov 26, 2017 #3 I raise my fel fully and curl my bucket, drain oil, leave plugs out, dump bucket, lower fel, do the same on my hoe. If you want to do it fully you need to pull pins on rams, work them both ways, drain hoses etc., lot of work.
