bx25d vs b7500
Smf834
L2501dt
Nov 1, 2021
52
1a2b3c
How do these two measure up in working on uneven grounds? I have a slight slope with uneven grounds due to lots of dead branches, stumps etc that i would like to clean up. The B7500 supposed to have 12" ground clearance vs 8" on the bx25d. What else could be a deciding factor? Thank you.
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
238
88
S.E. TN
Wheel/tire size. Larger tires on the 7500 will fall in the holes and ruts less. Plus its probably wider and more stable on hillsides. Ground Clarence is important if you get into brush stumps and bramble. Being heavier is an advantage while pulling stuff out of the ground. you also can’t ignore the increased loader capacity.
I had a 7500 once and it was a good machine for its size.
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
Another thought…the bx25d is a TLB isnt it? Does the B7500 have a backhoe? Do you need/want a backhoe?
bearskinner
Sep 1, 2014
926
242
N. Idaho
I have used my BX25D backhoe to build quite a few buildings, plus lots of trenching. It’s a smaller bucket, than a mini excavator, so it takes a little longer. Definitely worth the money spent on it.
bearskinner
Sep 1, 2014
926
242
N. Idaho
All dug with the BX backhoe, plus so many more. Once you get good, you will be amazed how productive it is.
440010A8-630F-4213-B2AC-4DDAE4B95A8D.png B82FD0FC-8A7A-4D4D-BE5D-E4A77B212BF7.png 3B7E4A4B-6528-4A11-9361-0113B6402544.png 7F32D8F4-D16C-4625-B35D-F3F94E412C30.png
3,395
the 25d indeed has backhoe. I am not sure how a backhoe on a subcompact would be useful enough.
A small backhoe is very useful compared to using a pick and shovel. But a toy compared to a full sized backhoe, which is just common sense...
For me, a backhoe has proven over the years to be very worthwhile. Same for my son in law who has a BX23S...
