BX25D Hard to Start
Hillbilly Engineer
BX25D, Land leveler
Apr 20, 2015
25
Cadet, MO
Normally my BX starts on the 3rd or 4th rotation and starts right up. Lately even with the temp at around 50 degrees I have to crank and crank to get it to start. I'm getting the glow plug icon and letting it preheat like normal. Once it starts and gets warm, it starts right up without any problems.
Any ideas on what could be going on.
2,831
how old is the fuel ????
fuel filters?
how many hours?
Grouse Feathers
Feb 16, 2015
1,022
11
Lovells, Mi
Where are you setting the throttle to start? The manual says to set it to about 1/2 throttle. It seems to make a big difference on my BX2370. Close to the bottom and it is hard to start.
8,744
Could be not actually heating the glow plugs. ;)
Could be water or other contaminates in the fuel.
Hillbilly Engineer
BX25D, Land leveler
Apr 20, 2015
25
Cadet, MO
I agree... I'm thinking it's related to the glow plug. I need to figure out how to check the glow plug.
If it was fuel I would think the problem would be present every time I try to start it and it would run rough and show other problems.
Once it starts it runs great, and will start and run just fine after that.
I bought it new 11 months ago, I'm thinking it's still in warrenty ( I need to check my paperwork) and might just take it to the dealer.
I know, letting someone else touch my baby...
I do love my BX.
GlueGuy
2018 BX23S, 3PH, Back Blade, Rake, 18ft Trailer
Apr 4, 2011
25
Newport, North Carolina
Just a thought, but check the fuel shut-off (STOP) solenoid to make sure it's open all the way. If you've ever noticed a loud click a few seconds after you stop the engine, it's this solenoid returning to the open or run position at rest.
When you turn the key to "OFF" the solenoid closes to block the fuel flow which stops the engine and then returns 5 seconds or so later with that "click". I've had to replace them on 2 tractors this year!
pmr49
9
Renton, WA
Don't ask me how I know this, but
don't overlook the obvious. Double check that the battery ground clamp is firmlybolted, and doesn't just look good.
Hillbilly Engineer
BX25D, Land leveler
Apr 20, 2015
25
Cadet, MO
Ok here's the update. I took my Tractor which was still under warranty to Waydes Equipment In Steelville, MO. I highly recommend these guys, a family owned and operated business with great customer service.
Bottom line.... The intermittent problem was the fuel shutoff solenoid. They replaced it and i'm back in business.. Thanks to everyone for their help...
