My little guy does not start readily even doing 20 'Mississippis'. I need to test the glowplugs. Anyopne got the ohms I should be reading at the plug? I assume full battery voltage is also expected.
Thanks!
Thanks!
unhook the leads at the top.My little guy does not start readily even doing 20 'Mississippis'. I need to test the glowplugs. Anyopne got the ohms I should be reading at the plug? I assume full battery voltage is also expected.
Thanks!
That's why they get HOT.1 Ohm, so nearly 100% resistance. Huh.... I would of guessed it would be 10 to 100 times that. At one Ohm, that is a near short.
That's not quite right. 10 volts across 1 ohm will net 10 amps, and power is volts times current. The glow plugs would be around 100 watts.1 ohm is not 'nearly 100% resistance'. It's just a low value....
I've got resistors from .01 ohms to 100 Megohms in the 'shack'.....
Those glowplugs are designed for 10 volts, so about 10 watts of power. Connect to 1 volt, only get kinda,maybe warmish...
If... after testing Ohms, I find one out of spec, I'll get a replacement and then for fun, do the bench test of the questionable one.That's not quite right. 10 volts across 1 ohm will net 10 amps, and power is volts times current. The glow plugs would be around 100 watts.
But that doesn't tell the whole story. 100 watts focused into a small point will be hotter than 100 watts over more material. Think of a 100 watt light bulb filament vs 100 watt space heater coil. Glow plugs focus the energy to the tip, and are not designed to be "warmish". Every diesel glow plug I've bench tested gets bright red to almost white hot. I actually just bench tested mine for the coming winter and verified they get extremely hot after 10 seconds. A bad glow plug would either take a long time to heat up, or won't reach an effective max temp to efficiently ignite fuel.
Yes.Do y'all anti-seize them?
