BX25D block heater removal and replace
Mowbizz
Bx25d
Aug 19, 2021
450
256
There was some kind of “hack” for removing a failed block heater on a BX.
Anyone recall the what that removal hack was? If I recall, it had something to do with “garden hose” threads to wiggle the old heater out of the block. I know I have to drain the coolant and I have the “kit” for doing that…getting the bad “pressed fit” unit out is my question. How?
5,191
If it's the kind that has the nut in the end:
Turn it out, yes I know there are no threads but it will still come out.
If its the kind that has no nut:
#1: If you can get a pipe wrench on it and turn it.
#2: A big pair of channel locks or a small hammer and work it side to side to get it to pop out.
Mowbizz
Bx25d
Aug 19, 2021
450
256
Thank you! That sounds pretty easy! Not quite ready to do the job but when I do your answers will be helpful!
BX'r
BX2370
Jun 13, 2020
73
14
ipsc
This is the type of heater on my BX2370.
To remove it I use a female coupling screwed to a threaded pipe from a pipe clamp, use a couple of round weights on the pipe with a coupling and washers to keep the weights on the bar.
Thread the coupling attached to the bar onto the heater and use the weights as a slide hammer.
The heater comes straight out.
Use a large socket to seat the new heater and add some blue locktite.
It helps to have a second set of hands to support the bar while you slide the weights on the bar.
Mowbizz
Bx25d
Aug 19, 2021
450
256
That’s awesome! Thank you !
BX'r
BX2370
Jun 13, 2020
73
14
ipsc
That’s the same heater I have..
I went through a couple of these heaters before adding a timer and now it seems to last.
I remotely turn the heater on from inside the house, it's on for twenty minutes and off for five and so on.
I think the space is so small around the heater they get hot and burn out when left on too long.
Mowbizz
Bx25d
Aug 19, 2021
450
256
I went through a couple of these heaters before adding a timer and now it seems to last.e.
I remotely turn the heater on from inside the house, it's on for 20 minutes and off for five and so on.
Yes, this is the 3rd one for this bx.
I have a remote as well but not on a timer. Perhaps it’s time for one.
5,191
Yea heating it all the time is costly part and electric bill wise!
5,191
These little engines don't take long to heat up:
This is just my opinion on years of use:
15 min normal cold temps
30 min really cold temps
