Thought I would ask the pros!
So last year I learned the hard way the tractor doesn't like 20 degrees below zero. So since then, I have been adding a anti-gel additive to my fuel. I never know when they switch to "winter mix" or if they did, so I just always add the additive. In fact, I have been adding double the recommended amount just in case. (the packaging says it will not harm the engine to add more - right or wrong) Yet, I was trying to get some things done yesterday and had a hell of a time. It would run for 10minutes that keep bouncing back and forth between good and rough. I was working in 25degrees the day before and didn't have one problem, yet yesterday it was 18 degrees and it didn't like that at all.
It's a 2014 Kubota BX25d. It's been about 100hrs since I have changed my fuel filters. I have about 350hrs on it.
First question, what can I do to get up and running? It should be a few degrees warmer the next couple days so might just fix itself.
Second question, what can I do besides additives to not have this issue. I was going to buy an engine block warmer, but not sure how that would warm up the fuel lines/filters? Could I get some heat tape and zip tie it around the fuel lines and filters and plug it in? or is will that make my tractor explode?
Is this additive, which had decent reviews, just junk?
Really ticks me off when you need to move some snow, or get a vehicle unstuck and the tractor refuses to move! As I was sitting on my tractor as it was acting up I could see my neighbors 80's kubota cleaning up his driveway. So I know I am doing something foolish...
Here is video of it:
https://www.youtube.com/watch?v=Mcm0rmG-imM
Thanks for any help!
