BX23S Under Belly Mower
WAS BANNED FOR NSFW PICS
5,157
I am picking up a 60 inch kubota mid mount mower deck RCK60B23BX tomorrow. I am assuming that the parts necessary to hook it up to my BX23S are already mounted on the underside of my tractor. What are the parts that I should make sure that I get with the mower deck other than the driveshaft and the front mounting bar? Are all the front mounting parts already on the BX23S? It comes off of a BX 2670. Everything that I have checked says that it is correct for the BX23S, is that correct information? Thanks
Mitjam
Jan 14, 2013
348
420
Edmonton, Alberta, Canada
I am picking up a 60 inch kubota mid mount mower deck RCK60B23BX tomorrow. I am assuming that the parts necessary to hook it up to my BX23S are already mounted on the underside of my tractor. What are the parts that I should make sure that I get with the mower deck other than the driveshaft and the front mounting bar? Are all the front mounting parts already on the BX23S? It comes off of a BX 2670. Everything that I have checked says that it is correct for the BX23S, is that correct information? Thanks View attachment 135106 View attachment 135107
Been a while since I had a bx but looks good to me. If you have the driveshaft, the front parellel linkage, and the locking mechanism on the front of your box should be good to go. The lift arms on your tractor should be there already. Good luck remember to set your height adjustment to 0 for easier install when letting down your arms to hook to mower
Mitjam
Jan 14, 2013
348
420
Also if your mower will not lock up in top position once attached there is a adjustment by the drivers rear tire, also stated in the manual
Ringman308
Bx1880-1
Jul 28, 2024
East Texas
You need the link bars if you don’t have them. i call it the hanger bar and the handle. Both are shown on top left end in the photo below. Connects the front of the deck to the front underside of the tractor.
4,403
Ringman you beat me to it,, YES make sure you have those pieces,, it wont work with out them to hang the deck
armylifer
Mar 26, 2013
2,239
997
Thurston County, WA
Also make sure that you get the drive shaft for the mower.
John T
2017 BX23S
May 5, 2017
1,081
564
under a rock
Looks like everything is there....
Messicks has a pretty good video on mounting/removal.
turn the front wheels all the way to one side and it's easier to slide the mower under....
also, those anti scalp wheels will turn sideways... so the whole thing will roll sideways...
I don't usually turn them... but it may make things easier till you get the hang of it.
PS, make damn sure the locking collar on the driveshaft is properly clicked in.
it's tricky.....
