BX23S, Redline SSQA Fork set [Modification?]
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
I'm curious if anyone else has the Redline SSQA Fork system, who has modified the fork frame for use on the 3PH. I cannot figure out how to do it.
11,110
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Post pics of what you have and are trying to achieve
I'll have to get pics at a later time, as my BX23S isn't equipped for that right now. I was hopeful someone with a BXxx has the Redline system, who may have modified them for 3PH use would chime in.
I'll edit my OP to reflect my model...even though that info is in my signature.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
mikester
M59 TLB
Oct 21, 2017
4,130
2,826
www.divergentstuff.ca
Sorry I don't have a clue what the Redline system is.
6,296
fairly simple mod, just add pins for cat 1 on bottom, +-26" and a 'top link' mount 7/8" holes
That $300 adapter is an easy solution ,though it does add weight and moves forks back.
Another option would be to buy $150 3PH 'carryall'.
Trimley
Jul 25, 2023
1,181
872
PNW-WA
Due to the design, I can't add the tabs easily where they make the most sense. They'll be right in the middle of the plate face. A carry-all was the plan. If I dont come up with a simple way, I'll probably just add the ears and toplink mod to the trailer box I plan to use.
retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Dec 1, 2020
110
115
Bloomington, IN
Hi - I worked up a design for mods to my Landpride forks - I already had a Titan Aerial Work platform for the forks that I tricked out as a carryall. Wanted to be able to carry it on my quicktach 3PH, so that I could have the bucket or grapple (or grapple in bucket) when I'm out working.
Here's the post with my mods: https://www.orangetractortalks.com/...s-for-use-on-3ph-quicktach.60553/#post-599968 I have no welder or skills, but Dusty, the mechanic at my Kubota dealer, fabbed the mods for me.
6,296
you may find a 3ph carryall BOX is 'limited'.
using a 3ph carryall allows you to pickup any number of skids. I tossed a LOT of 'stuff on skids, hauled them here,there,everywhere. learned fast to 'double skid'. Set the skid of stuff onto another skid. The lower one kept the top one from being water damaged and made it easy to fork.probably had 30-40 skids of stuff here...stones, rocks, lumber,paving stones,tractor parts,mowers, etc. Put old shipping crates on a few to store 'stuff' out of the weather.
other benefit is it's a LOT easier to mount JUST a carryall than a 3PH carryingbox !
Might be an option to consider.
John T
May 5, 2017
1,320
833
under a rock
Question,
Does a 3PH carry all OR a 3PH pallet forks have more lifting ability than front loader forks?
I assume it would.... due to the short travel ... / not all the way out there like loader arms
John T
May 5, 2017
1,320
833
under a rock
3PH implements are handy..... but for me it's a pain in the arse.... the BX23s you have to take off the backhoe mounts and then put on the 3PH ...... not really user friendly... unless you leave it on all the time...
I get more use out of the backhoe....
maybe I need 2 tractors... :LOL::LOL::unsure:
John T
May 5, 2017
1,320
833
under a rock
speaking of taking off the BH
I keep myself in good practice..... I take the loader & BH off weekly to cut the lawn.
it's very quick when you get the hang of it.
Dec 1, 2020
110
115
Bloomington, IN
Question,
I wouldn't trust a carry-all frame (like RK/KK) to handle much more lift than the loader. Forks - probably rated 2k-4k - more than my loader can lift. I haven't tested them lifting from the 3PH - like on a 10' wet sycamore log that the FEL can't lift - after going through getting the 3PH adaption fabbed, I figure if it's too heavy for the FEL, I'll drag it from the towbar from a chain. Call me chicken.
6,296
My other orange tractor would lift 1800# pumpkins with the loader, carry a 3200# black walnut log on the homemade carryall. Yup, a tad 'light' in the front for steering but NO problem lifting the logs.
My BX23S loader lifts maybe 500#, 3PH I think is rated for 1000 ? Would need to find the book to be sure.
