BX23S loader mounted tool box
Crash277
BX23S
Jan 17, 2021
846
622
Sun was shining all day, I had a bit of time to kill. Got bit by the DIY bug. Decided to finally mount the Plano ammo box to my loader. All made from scrap steel and leftover bolts from other projects. Only time I take my loader off is when I mow, so I figured since I can put the quick attach valve block into the random hole behind the actual mount that I would use it for the toolbox.
i7win7
Feb 21, 2020
3,228
3,740
Central, IL
When you have an older loader
Crash277
BX23S
Jan 17, 2021
846
622
Started filling it up. What do you guys typically carry?
2 19mil wrenches
1 hammer
1 adjustable hammer (thumb wrench)
Assorted pins
Spare top pin
going to add
Wrench for the tilt adjustment
Large punch
Side cutters
Zip ties
Rags
Small container of grease
Latex gloves
i7win7
Feb 21, 2020
3,228
3,740
Central, IL
Side cutters - when mower eats something it shouldn't
little pricey doesn't make tangled mess in box
I'd reconsider the grease - too messy
Spare fuses, 10mm wrench to bleed air out of fuel line(field filter replacement)
grease rags - not sure about gloves
Make labels for toolbox lid
4,059
good...until, you forget to lock the lid(or it fails...):(, raise the bucket up, EVERYTHING falls into the pile of poop you WERE moving
i7win7
Feb 21, 2020
3,228
3,740
Central, IL
Where do you get your smoking supplies?
3,842
For 17 years, and 800 hours, I never needed anything other than some mosquito repellant. I must be very lucky!
Crash277
BX23S
Jan 17, 2021
846
622
hopefully they fall in a nice neat pile. Haha
if I decide after a bit I don’t like it there, it’s easy to remove. Would be nice if the fuel tank fill was on the left side, I have seen the swing out toolbox mounts for the rops and I may end up doing that eventually.
