My dealer is recommending 80W/90W for my front axle. That’s not what the book says but just wondering if anyone else is using it? Did the 50 hour a little early and the fluids were very thin. The dealer told me they put 5W in at the factory.
Thanks for your reply. My dealer did say I would probably have leaks with the thinner oil. I already put the 80W/90W in so I’ll see how It goes. I don’t know what the dealers charge for the 50 hour service but it cost me $200.00 just for all the filters and fluids. I did replace all fluids and filters though. Book doesn’t call for fuel filters or changing trans fluid but my dealer recommended it so I did it.I am not sure what this year's BXs come from the factory with in the front axle, but my L3560 and B2650 came with SUDT2. At the first recommended change, at least one dealer has recommended to me that I use 80/90 oil instead. While some people say that the seals hold up better with that oil, others including Kubota say that SUDT2 does not cause leaks. However one Kubota tech was of the opinion that the thicker oil would be lost at a slower safer rate in the event of a leak. The manuals say either oil is fine. Take your choice.
When I got my BX24, the fluid was below the dipstick. The seals on the right side were leaking. I filled the axle with 80w90 and it stopped leaking. There is no reason you need to run SUD fluid in the front axle since it***8217;s all gears and bearings. In my opinion, gear oil is a better choice.
The owners manuals for both my M's and my previous Grand L 5030 all said SUDT or UDT or 80-90 gear oil. I use 80-90 GL5 Hypoid oil in both the M's front axles. I do that for shock load reasons but my owners manuals say I can. Could be intrinsic to those tractors, not sure. Next to the last axle lube change I used 85-140 Spirax with no issue but this last time it was 80-90 Spirax instead.I am not sure what this year's BXs come from the factory with in the front axle, but my L3560 and B2650 came with SUDT2. At the first recommended change, at least one dealer has recommended to me that I use 80/90 oil instead. While some people say that the seals hold up better with that oil, others including Kubota say that SUDT2 does not cause leaks. However one Kubota tech was of the opinion that the thicker oil would be lost at a slower safer rate in the event of a leak. The manuals say either oil is fine. Take your choice.
