BX2380 50 Hour Service
JimDeL
Aug 31, 2022
373
422
Austintown, Ohio
Lotsa YouTube videos showing all the fluid changes, etc. for a 50 hour service, but the owner's manual chart only shows changing the engine oil and filter and the transmission filter (not the fluid). So... should I just follow the manual, or should I go the full route?
Also, if I want to just change the tranny filter, how much fluid will I likely lose when removing the filter?
TxTom
L3301
Sep 16, 2022
Leon County, Tx
I just changed the trans filter only on my L3301 and almost filled up a 6 quart bucket I put under it. I had enough on hand to replace that fluid but you can strain and re-use it if necessary as long as the hours of use are within recommendations.
2,858
Jim,
the ONE part of this puzzle is the suction side screen - IT should be cleaned at 50 hours......
Now to do this requires some magic or patience or both.
There are ways to keep from loosing a lot of oil as this is pulled out - but, for the time and energy - go AHEAD and empty all the oils (engine and hydraulic) and clean THAT filter well - replace all filters and date and hour them.
Also check the front axle - it too is known to be low!!!
This way - everything is good to go and when 200 hours come around ........ you will know that it has had the best service possible.
