BX2370-1 w/Hodges Bars
CountryBumkin
Sep 27, 2015
568
Central FL
What do the Hodges Bars do for you?
I would think the quick hitch/connector (like Pat's http://www.pats3pointhitchsystem.com/page/7229) would be more useful - or maybe a combination of the two.
Not trying to put down your purchase - just want to understand how helpful those Bars are.
TripleR
Sep 16, 2011
1,911
38
SE Missouri
They make adjustments so much easier than the turnbuckles whether you have PATS or not. I have them on both our BXs.
hodge
Nov 19, 2010
2,854
367
Love, VA
If I may, I will respond in reference to telescoping stabilizers in general, over turnbuckles.
I just built stabilizers for two different customers who had broken their turnbuckles. That isn't uncommon, and neither is stretched threads. With turnbuckles, only one side holds the load- the side that is being pulled against. The other side does nothing, due to the loose mounting system, and the nature of a turnbuckle. Telescoping stabilizers, on the other hand, hold both under tension (pulling), and compression. So, both sides keep the load stationary, making the system stronger and less prone to damage. A quick hitch has no effect on that- it depends on the stabilizers to hold it stationary. So, while a quick hitch could make telescoping stabilizers unnecessary because a person isn't having to adjust them when changing implements, the weaker design still has a bearing on how the system holds up. Telescoping stabilizers, in conjunction with a quick hitch, is a simple to use system, that is also stronger.
4,051
Bumpkin - you heard it from the manufacturer himself!!:D
If I did more 3ph work, I would order a set in a minute. I have heard nothing but great things about Hodge's great product!:D
olthumpa
L275
May 25, 2011
1,501
Maine
The only regret I have with Hodges stabilizers is, I wish I had ordered them sooner. :)
CountryBumkin
Sep 27, 2015
568
Central FL
Thanks for explaining Hodge. I'm learning something new every day on this site.
L4740
222
3rd Rock From The Sun
Where can someone find more information about these? I found a link to your video on youtube. It referenced your website. However, when I attempted to go to your website, it says that specific website is for sale? Did you change your url, or are you no longer taking orders for these. I would at least like to see what is available, for what model tractors and cost. Any help would be appreciated. Thanks in advance.
hodge
Nov 19, 2010
2,854
367
Love, VA
I no longer have a website, but you can PM me here, or email me at markhdg@gmail.com.
eddiebob
BX2680, JD 40
Mar 23, 2014
217
Poplarville, Mississippi
No offense taken. And of course Mark answered your question much better than me. His stabilizer bars are top end and you will not deal with a better person! After 10 years of use the turnbuckles on my old tractor were unusable. Adjustable stabilizer bars should be standard equipment. Do yourself a favor, get a set, and never look back. Ed B
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
If you can't find them, any welding shop can do the job for you. Or, with a little equipment why not make your own? I'd size up what equipment will be attached and set the hole pattern accordingly. I'd opt for quick hitch for most of the the time even with those bars in use there. However in my experience of some 20 years for non farm use in the woods and big gardens, I never had any turnbuckle problems.
ipz2222
L235, bx2670
May 30, 2009
1,927
31
38
chickamauga ga usa
Before Iknew about hodges, I built my own. Got tired of all the time it took to hook things up. Sorry,, I don't have time to build anymore.
