I have a 2008 BX2350 that has developed a steering cylinder leak at about 475 hours. Rebuild seal kit is on order. It looks like it SHOULD be fairly easy to change all the O-rings. From those that have already done this, is there anything I should be careful of or look out for when doing this repair?
I don't know if this is relevant or not, but the last time I used the BX everything was fine. When I started it the other day, it just started to leak hyd. oil BAD from the right steering cylinder seal. I got it shut down before it leaked out more than a pint of oil. Is this typical of this type of seal failure? When they do fail, is it usually a rapid failure or not?
I'll post pictures when I get to doing this, IF it isn't too cold.
Thanks, in advance, for any and all advice.
Dave
Dave
