BX22 FEL Leaks Down With Load While Running
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
356
88
Canton, MS
I've got a BX22 with 1200+ hours on it. Today while using the FEL I noticed that it was leaking down while it had a load on it with the engine RPMs up at operating speed. I had gotten off the tractor to move something and noticed it leaking down when getting back on.
I've looked all over the tractor...hoses, quick couplers, crawled under it and cannot find hydraulic oil leaking anywhere. I'm open to any suggestions ya'll may have........thanks.
ehenry
Mar 25, 2014
356
88
Canton, MS
I forgot to mention the 3ph leaks down as well.
All three FEL cylinders were rebuilt last spring.
5,195
Why were all three cylinder rebuilt?
When was the last fluid and filter change?
Could be your sucking air into the system, but not very common on that model.
ehenry
Mar 25, 2014
356
88
Canton, MS
The cylinders were rebuilt because all three developed leaks at the seals but not all at the same time.
The last fluid change was probably 20-30 hours ago back in 2015.
Is leaking down the only symptom of sucking air? There was a fairly heavy load on the FEL when I noticed is leaking down.
5,195
No leaking internal seals on the rams is more common, same with the three point.
