Bx1500 mid pto issue
bpougnet
The mid pto is not functioning properly on my bx1500. All other functions work normal, hi low range, forward reverse, power steering, 3 point hitch and rear pto. If I select mid pto only, then try to engage the pto it grinds, if I select mid and rear pto the rear pto turns but the mid does not, there is no grinding at this point, if I select rear pto and engage, it turns normal with any noises. It just feels like when I move the lever to mid pto it just doesn’t go into gear it just has a grind sound. No noticable glitter in THD fluid. Have the ability to repair but was hoping someone else experienced a similar issue and could point me in the right direction, thank you and much appreciated in advance for any help.
10,622
Get the WSM and start studying how to take it apart. ;)
