BX 2660 blowing fuse
Finnagan
Dolores
Hi I am currently having a problem with the fuse associated with the fuel pump blowing, when I switch the key to on/run it immediately blows. I also have no dash lights and none of my lights work, no tach temp, or fuel level. I am not sure if the same fuse powers the dash with the fuel pump, but I now have a giant paperweight. Are there any known fraying locations that bare wires fray over time?
Please let me know, thanks.
5,154
Disconnect the fuel pump and see if it still blow the fuse, if the fuse stats intact through all the key movements then you have a bad pump, if not your issue is somewhere else! ;)
