BX 23 Front Drive Shaft
5,501
2,208
never had one so stuck that a hammer and good quality punch wouldn't knock it out
bent many a cheap punch though....
the nail in the coffin with cheap punch sets was when a chisel tip/corner broke the tip off and went through my right cheek. Not the butt cheek either!
Dave Ogren
BX23S w/FEL &BH &60" Mowing Deck, 48" Dirty Dog Box Blade, 48" Tar River Tiller,
Feb 16, 2022
100
47
Asheville, N. C.
thanks...I get the idea, but will google it as well...I'll go spray some WD-40. Maybe that will loosen some things up!
If the WD40 doesn't work try a product called Thrust, it has never failed me, been using it for years. Only sold by area distributors I think. Not in auto parts stores.
WAS BANNED FOR NSFW PICS
5,153
I use Kroil and Deep Creep, and neither has failed me ever! WD40 is not a good penetrant. In this case, since you are going to be replacing the shaft, then heat is your friend. Time to break out the hot wrench!
Edgemoore
BX 2380
Dec 27, 2019
17
colfax
Something I have used on my classic Mini Cooper when trying to drill in a difficult place was to use a 1/16" drill bit on a Dremel with the 90 degree adapter. The speed of the Dremel will make a quick starting hole with a good drill bit.
thanks...I may need to try this option..
